My mom got a free PC from work. quick question.
atomic3
So my mom brought home a PII-266 MHz w/ 64 megs of RAM from work. I went ahead and installed XP on this thing, and needless to say.... it's slooooooooow. I did some research and found out that this particular machine (Dell Dimension XPS D266) can hold up to 384 megs of ram. Would there be significant performance increases if I maxed out the RAM? I am just looking for improved loading of programs, and faster general operation. This machine is strictly a word processing and internet browsing machine. Thanks for any input.
You'd probably still be better off running Windows 98 on it though.
The extra ram won't help alot in XP. If you get 256 and put w2k on there it will be a whole lot better. If you really want XP, turn off ALL the eyecandy.
More memory certainly won't make it any slower.
For great justice, put Win98 on it. It will run better with Win98.
I have it set for "best performance" so all of the eye candy is turned off. I would put win 98 on it but I don't have a copy. This PC came with a formatted HD, so I had no choice but to install XP. Upgrading the RAM is my only feesable option.
use windows 98se if you can get ahold of it. Its much better than regular 98.
For speed, and power, use beos 5 PE www.bebits.com.
45mb download (About 500mb when expanded), can be installed onto hard drive, or just copy and run from dos. it runs somewhat fast on a P90 with 32mb of ram. I use it for video editing, and cd burning. I used to run it on my 233mhz Gateway with 192mb of ram, as a HTPC. It had the power to watch tv and record it in raw AVI format without dropping frames.
Is that computer worth spending money on? I was over at a friends house earlier messing with his computer. It is a Celeron 333Mhz with 256MB of RAM and Win ME and I was about to pull my hair out. It took 15 minutes to fix the problem when I could have done it in 2 on my machine.
You might want to try the "tweak for a gaming machine" on www.tweakxp.com and see if you get better results.
What do you mean formatted HD? Why would that matter? Hard drives are always formatted if they are intended to be used. Do Dell's contain something on the HD that is used with the factory OEM Restore disks?
There is probably more than just the CPU/RAM holding it back. The hard drive is probably slow too, considering when it was made and the considering it is in a Dell. Dell doesn't splurge on hard drives when reagarding speed along with most OEM's. Size is thier only selling piont, so they put that first and sacrifice speed.
I believe he meant that the company wiped the drive before they gave it to his mom. I don't think any company in their right minds would give away a computer with sensitive material still on the HDD.
Ahh, understood.
I'd install linux and use it as a firewall. Adding extra memory would help a bit in XP, but your proc is definately a bottleneck. You might be able to upgrade to a P2 450mhz pretty cheap.
My two cents - I have an IBM Thinkpad 600. It has a Pentium II 266. When I got it my uncle had installed Windows XP, and it had 64 meg of ram. It was slow. Everything was slow. Internet browsing, Word, you name it. Page file was definitely used a lot. I upgraded it to 160 meg of ram off of ebay (64+64+32onboard). The extra 128 did wonders. The only thing holding your new computer back from being usable is the RAM in my experienced opinion.
Upgrade the RAM, enjoy Windows XP (enjoyable when compared to Win98).
Depending on how many ram slots there are, and what size chips are already in it, i would just put a single stick of 256 to add to whatever you can in there already. 288 or 320 meg of ram will be fine.
Agreed. Find a proc on the FS/FT boards here along with some cheap RAM, and you could have a decent web machine for $50.
I had a 266 running XP and more ram helped a lot although it was still very slow. I tried Win2K on the same computer and it was not noticeably faster than XP for me.
Since it sounds like a project-type computer anyway, I agree with saturnine2 to try and get a faster proc for it. You can probably find one for $15 or $20.
max the thing out with memory, and do up windows 2000 professional. I was running a similar computer a few years back, and windows 2000 ran very nicely on it. don't even bother with xp.
If you are going to be useing it just for the internet and word processing. Go with win 98se, it can be had for under $20 these days or see if a freind or other family member has a copy that they no longer are useing.. I would however recomend using any web browser other than IE.. firefox and a few others are free and will help with some security issues..
You might want to upgrade the ram. But be sure it can take the size of any module you put in it. Alot of the older mobos won't recognize a module larger than 128. Considering yours maxes @ 384 it is prolly one of them. See if where she works has any more comps like that one that they are giving away.. could use the ram out of one of those to upgrade the one you have
I have a similar computer at home that is used for web browsing / word processing. Its a dell PII 350. I run win2k and it runs very fast, for web browsing there is little difference than that and my main rig.
I added extra ram, right now its using 128+64+32 = 224 which seems like enough. I did do several upgrades that helped a lot. One is the video card... it was an 8MB nvidia something or other. I upgraded that to a Geforce 2 GTS 32mb which made a big difference when loading web pages. I also added a 7200rpm drive which increase startup times.
I would recommend a better vid card and memory which can be had for under $70. Remember to get PC100.
Add the ram,
delete every startup pgrogram,
change the visuals so that XP looks like 2004
should work
I spent 5 years with a 233mhz P2 with 300something RAM
95->98->2000beta->XP
win95 was the worst
Bump up the ram and go 2kpro, I have an old amd233 still running as a file server at my office with 128 meg of ram. It just wont die
GORANKAR said:
If you are going to be useing it just for the internet and word processing. Go with win 98se...
Am I being ignored? BEOS 5 PE, 40mb download. Free, Fast, Fun, and reliable. You can download Abisuit, and mozilla. There you go, word processing and internet.
So..you don't think that going from the MINIMUM amount to run the operating system, to 500% more than the minimum will make any difference?
Odd opinion, that one.
For a 266mhz machine, your bottleneck will no longer be in the RAM. The CPU will severly limit things that you can do.
