VoodooChi|d
- May 3, 2005
I know this just came out so there aren't many reviews out there. Although I cannot compare it to the DiNovo (sp?) I'll do my best to give a thorough review of the product. I had a coupon for an online retailer and they were the cheapest retailer for the product so overall I got it for a decent amount under the MSRP of $150
What's Inside The Box?
(1) Microsoft Wireless Entertainment Keyboard 7000
(1) Microsoft Wireless Laser Mouse 8000
(1) Microsoft Mini USB Bluetooth Transceiver
(1) Recharging Dock for Mouse
(4) Standard AA Energizer Batteries
(1) Rechargeable 2000mAh AA Energizer Battery
Overall Appearance/First Thoughts
The box is very flashy box which I guess is supposed to help you justify making the $130-150 purchase when you see it in the store. The box is also hard to open and get everything out. After figuring out how to open it I was very impressed with the look of the product. Very sleek, sexy, and everything I expected/was hoping for. The fit and finish was also superb.
The Keyboard
The keyboard is really the main feature of this mouse & keyboard set. It is the first keyboard designed specifically for Windows Vista and only works in XP MCE, Vista Premium and Vista Ultimate. Basically if your copy of Windows has Media Center it will work. There are quite a few nice/new features of the keyboard and a few drawbacks as well. The keyboard is laid out in a semi-curved shape, similar to the ergonomic keyboards but there is no key "break" between them and it isn't as curved as an ergonomic keyboard as well. It is very thin and designed to be used in your lap although I have used it just fine on a keyboard tray on my desk. There are no legs to make the keyboard slope but this wasn't a problem for me. The keyboard is not as wide as a standard keyboard with number pad but the extra keys on the side make it wider than a standard mini-keyboard. One feature I really enjoyed that surprised me is the darker gray area at the bottom of the keyboard. It is a rubberized plastic which although doesn't substitute a wrist pad if you use one does make it more comfortable to use and I thought was a nice touch. The keys are similar to a laptop keyboard but I found it easier to type on than my laptop keyboard. I'm not sure what makes it this way but it was an observation I paid attention to. What really makes this keyboard special is the connectivity with Media Center and Vista it has. There is a key to bring up the "gadgets" to the front of your desktop, a key to start Media Center, a key to start the magnification tool, a key to make a call in Windows Live, both volume and channel keys for Media Center. Play/Pause, Record, Next Track and Last Track keys are also included. The "Windows" key has been moved to the bottom middle and slightly recessed to prevent accidentally hitting it which is a nice feature. Another feature of the keyboard is an on-keyboard touchpad for mouse-like control. The layout of the touchpad and right and left mouse keys is nice but the touchpad would be better if it were slightly bigger. Also, the default sensitivity on the touchpad is very low so combined with its small size it takes a lot to move the cursor around. This can easily be changed in the keyboard settings. I believe the DiNovo has an up and down scroll feature on its touchpad which would be a nice feature to have on the 7000. Another interesting feature of the keyboard are the Function Keys. They aren't keys at all but rather touch sensitive. Not really useful in any way besides to save space and look cool but it doesn't hinder performance any either. One negative to the keyboard is the fact that unlike the included mouse it isn't rechargeable. MS claims 9 months battery life so it isn't that big of a deal but it would be nice. Overall I think the keyboard is excellent both as a Media Center "remote" and as a standard keyboard. If I needed to use the number pad which is obviously lacking that might hold me back but I don't. The included "Vista" features are very useful and it looks and performs amazing.
The Mouse
Since I believe the mouse has been out a while and isn't anything too special I'll keep this short.
Good:
Wireless Bluetooth
Rechargeable
Comfortable
Accurate
Attractive
Bad:
Somewhat off-center weight might bother some people
It's also not a true gaming mouse but I have no problem using it as such
Recharging base would be better if it were USB. Trying to find a free outlet near the computer is hard.
Overall: Excellent mouse and it matches the keyboard very well. My only real gripe is the recharging base.
Final Thoughts
While the keyboard and mouse combo may not be for everyone it is an excellent product. If its one-of-a-kind features meet your needs you owe it yourself to get it. It is worth every penny in this case. It is extremely attractive and easy to use and wouldn't look out of place in a state-of-the-art media room. The included bluetooth transceiver is also a very useful tool by itself.
My "score": 9.5/10
The Keyboard
The Mouse
Good:
Wireless Bluetooth
Rechargeable
Comfortable
Accurate
Attractive
Bad:
Final Thoughts
My "score": 9.5/10
