Shakezilla
- Aug 15, 2004
He relatively new Im posting this for him, I dont really agree with his PSU choice. But give your suggestions
So I'm looking into building a new computer, just got a check for $1000 so that's essentially my budget. This will be the second computer I've built, the first of which I made about 4 years ago and is no longer cutting it. I plan to use my current moniter, keyboard, mouse, speakers, sound card, and Antec case. I also plan to use the current 80G hard drive with windows on it in addition to a new, larger HD (see below). The parts I'm looking at are listed below, I'd appreciate any advice or comments on them but I'm mostly looking to make sure that what I have picked out will work well.
Mobo: ASUS P5N32-E SLI LGA 775 NVIDIA nForce 680i SLI ATX Intel
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131073
Chipset: NVIDIA nForce 650i SLI
CPU Socket: LGA 775
Cost: $210
Processor: Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA
775 Retai
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003
Socket: LGA 775
FSB: 1066
Cost: $225
Video Card: XFX PVT71JYHE9 GeForce 7950GT 512MB 256-bit GDDR3 PCI Express x16 HDCP
ExTreme Edition Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150189
Interface: PCI Express x16
SLI Compatible
Cost: $210 (with $20 rebate)
Hard Drive: Western Digital Caviar SE16 WD4000AAKS 400GB 7200 RPM 16MB Cache SATA
3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136076
Cost: $100
RAM (x2): Kingston ValueRAM 1GB 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200)
System Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144151
Cost: $80
XION Supernova XON-600F14R-201 ATX 600W Certified Power Supply 115/230 V cUL,CE,FCC,CB - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817190012
Power: 600W
SLI Supported
Price: $90 (with $30 rebate)
Total: $915 ($965 before rebate)
Any advice or glaring issues that should be addressed are much appreciated.
CPU Socket: LGA 775
Cost: $210
775 Retai
Socket: LGA 775
FSB: 1066
Cost: $225
SLI Compatible
Cost: $100
Cost: $80
Power: 600W
SLI Supported
