Well, I finally took the plunge and elected to get rid of my personal space heater of a PC to go with watercooling. Temperatures were horrific on air and come summer it would not have been pleasant to power this baby on. So here it is, a detailed review of my first time water cooling adventure on a modded CM Stacker 830 with dual 8800 Danger Den waterblocks, among many other parts. All system test were done at core clock speeds. As temps were virtually identical between tat, coretemp, and Everest, I elected to use Everest only for convenience and also so the tests would be consistent across the board. Fans were kept at the same RPMs throughout the test so the only variable that changed was ambient room temperature for the most part.
System Specs
E6700
eVGA 680i mb
eVGA 8800 GTX SLI
4 x 1GB OCZ DDR2-800 4-4-3-15
850w Strider PSU
CM Stacker 830 Case
Original Air Cooling Components- Zalman 9700 LED
- 120mm fans - front fan 1200rpm , top exhaust fan 1200rpm, rear exhaust fan 2200rpm, 4 side fans 1500rpm, 2 bottom fans 1500rpm....and so on, and so forth
- 40mm fans - 2 x memory fans 1200rpm...and even more fans
Air Idle Temps
Ambient room temperature 21.5c
cpu/40c gpu1/61c gpu2/61c mb/35c
Air Load Temps (max temps)
Orthos - ambient room temperature 21.8c
cpu0/51c cpu1/48c gpu1/61c gpu2/62c mb/36c
3dmark06 - ambient room temperature 22.1c
cpu0/50c cpu1/47c gpu1/75c gpu2/75c mb/38c
Vanguard Animated Character Selection Screen - ambient room temperature 22.6c
cpu0/47c cpu1/44c gpu1/83c gpu2/84c mb/41c
< Test #1 - Water Cooling on a Swiftech Mini Res with Distilled Water/Zalman G200 coolant 80/20 mix >
- D-tek Fuzion CPU block
- Swiftech MCP655 pump
- Danger Den 8800 GTX blocks
- Swiftech Mini Reservoir
- HW Labs GTX Xtreme 480 rad
- OCZ Ultra 5+ paste
- Zalman cooling fluid/Distilled water, 80/20 ratio
Fans Used with Water Cooling
- 120mm front fan @ 1200rpm and 4 x 120mm Silenx 1400 RPM 14dba 72cfm fans for the radiator
Water Idle Temps
cpu/32c gpu1/49c gpu2/44c mb/37c
Water Load Temps (max temps)
Orthos - ambient room temperature 21.5c
cpu0/42c cpu1/42c gpu1/61c gpu2/49c mb/45c
3dmark06 - ambient room temperature 21.9c
cpu0/42c cpu1/41c gpu1/54c gpu2/49c mb/39c
Vanguard Animated Character Selection Screen - ambient room temperature 22.2c
cpu0/40c cpu1/39c gpu1/55c gpu2/50c mb/38c
< Test #2 - Water Cooling on an XSPC 250mm Reservoir with Distilled Water/Zalman G200 coolant 80/20 mix >
- Swapped the Swiftech res with the XSPC 250mm Aluminum Reservoir
Water Idle Temps
Everest - cpu/32c gpu1/49c gpu2/44c mb/37c
< Test #3 - Water Cooling on an XSPC 250mm Reservoir with Fluid XP+ High Performance coolant >
- Using the XSPC 250mm Reservoir and Fluid XP+ coolant instead of distilled water and Zalman G200
Water Idle Temps
Ambient room temperature 23.4c
Everest - cpu/32c gpu1/46c gpu2/42c mb/36c
Orthos - ambient room temperature 23.4c
cpu0/42c cpu1/41c gpu1/48c gpu2/45c mb/38c
3dmark06 - ambient room temperature 23.5c
cpu0/42c cpu1/39c gpu1/54c gpu2/48c mb/39c
Vanguard Animated Character Selection Screen - ambient room temperature 22.5c
cpu0/39c cpu1/36c gpu1/55c gpu2/50c mb/39c
And the conclusion...........
As you can see from the above, the ambient room temps were almost the same in both the air and water tests, with the exception of the third water test where the ambient room temperature was over 23c. The water cooling really kicked in not only in idle mode, but especially when the GPUs were put to the test, cooling them almost 30c over air under load. With Fluid XP+ in the third test, GPU temperatures were 3c and 2c cooler respectively in idle versus the distilled water and Zalman G200 fluid. All in all, I'm very pleased with the results.
General comments........
- The swiftech rad is quite small and a pain to fill. If you want to fill and bleed with ease get yourself a bigger reservoir. Obviously if your case is small and you don't want to use an external reservoir then you don't have much choice, but the XSPC reservoir made filling and bleeding quick and easy.
- The barbs that came with the Black Ice 480 were the most problematic part of the system. The main problem was that they leaked even after I tried changing the tubing and doing various other things with the rad. I ended up having to replace the o-ring washer on them and moved them to the XSPC reservoir, swapping them with the longer XSPC barb. All other components were easy to mount and exhibited no problems whatsoever.
- The D-tek Fuzion block did not allow me to use clamps as the 1/2 tubing didn't provide any spacing. I ended up using zip ties, which worked just as well.
And now for some pics......
The only remaining item on my to do list is to cut out a grill for the top of the rad and fasten it on to protect the radiator. Look forward to your comments and suggestions!!!
Original box
Testing the loop
More loop testing....can't afford a leak...heh
Fully installed and cables cleaned up
Here's the custom mounted rad....what a monster
Rear view of the rad
Reservoir....brrr
Inside the case
D-tek Fuzion...great block, but no room for clips with 1/2 tubing
Danger Den 8800s
Front view
The Swiftech MCP655 pump...hidden away
A little darker
Lights out!
System Specs
E6700
eVGA 680i mb
eVGA 8800 GTX SLI
850w Strider PSU
CM Stacker 830 Case
Air Idle Temps
Water Idle Temps
Water Idle Temps
Water Idle Temps
Original box
Testing the loop
Reservoir....brrr
Inside the case
Danger Den 8800s
Front view
A little darker
Lights out!
