FrEaKy
[H] Movie and TV Show Review Guy
- Jan 31, 2003
I have been a major advocate for Windows 8 since its release, I really think under the hood its a great operating system if you spend some time with it, tweak some stuff here and there, it really is a nice OS.
Well, I have it running on my Dell Vostro 3550, and for the fun of it I was messing around with Neverwinter and was having a good time, but realized my graphics settings were TERRIBLE. Checked in the troubleshooting section of the video options to find it was only seeing the Intel 3000 HD graphics adapter. Odd. So I open up System, checking Device Manager and see the nice exclamation point besides my 6650M adapter. Okay, check the info, error 43. Okay, seen this before, stupid device signatures don't match. No biggie.
Grab newest AMD drivers, get it underway, get it finished, reset system. Nothing, same effect. No switching between the two adapters, cant select it, don't even see it.
Check around a bit, realized the Intel HD 3000 drivers are version 9.17 which Intel confirmed don't have switchable graphics option enabled anymore.
Okay, do some more checking, looked in Device settings, realized I had the same error for the AMD graphics adapter again as well.
Fine, whatever.
Grab the Windows 7 64-bit driver for AMD that has the Intel Embedded adapter drivers as well for the Vostro 3550 and install those, boom, Intel drivers are good (8.59 or something like that) and it recognizes my AMD, but as a generic AMD. Thats fine. Grab the 7650 drivers since its just a re-labeled 6650, graphics show up properly.
Nice
Go to run Configure Switchable graphics on the desktop right click menu. Nothing. It just sits.
Okay, reboot just incase.
Retry
Nothing.
Okay, fine, load ccc.exe
Nothing.
just sits.
Stare at it for a minute, go grab the latest CCC from ATI's site (http://www.ati.com/products/catalystcontrolcenter/index.html) and try again. Nothing.
Try compatibility and drop it down to Windows 7, nothing, drop it down to XP, nothing, run as admin, nothing.
Pull hair out
Finally have enough of this and finally give Windows 8 its first red mark in my book. This is a major pain in the ass!
Fine, whatever.
Nice
Retry
Nothing.
Nothing.
just sits.
Pull hair out
