xunknown87x
- Apr 4, 2005
Hello all, I have decided to go through and buy the parts to build a computer. What do you guys think on my build. I wanted to stay at 1000 for aiming for a budget build that would last me a good 2 years, then overclcock it or upgrade. Also, I will be running duel monitor with my 20 inch ultrasharp dell as primary, then my samsung 4071 as a secondary. Do you think this computer could handing playing a high def/blue ray movie on my TV while running a game on decent settings in a window and being able to browse the web without much lag? Any suggestions would be welcomed too, thanks.
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail 120.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply 100 - 240 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick - Retail 110
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139001
GIGABYTE GA-EP35C-DS3R LGA 775 Intel P35 ATX Dynamic Energy Saver Ultra Durable II Intel Motherboard - Retail 140
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128082
Intel Core 2 Duo E6750 Conroe 2.66GHz 4M shared L2 Cache LGA 775 65W Dual-Core Processor - Retail 190
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115029
EVGA 512-P3-N802-AR GeForce 8800GT Superclocked 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail 180
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130319
Western Digital Caviar SE16 WD5000AAKB 500GB 7200 RPM 16MB Cache IDE Ultra ATA100 Hard Drive - OEM 105
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136111
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail 36 X 2 = 70
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146565
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner with LightScribe - Retail 33.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106072
= 950
Then I haven't really decided on an operating system. I hoping I could maybe get one from my dads work for free, but who knows.
= 950
