My first gaming rig - what do you think?
Rob001
This is going to be the first time i've built a system from scratch. It's going to be used almost purely for gaming (i've got a laptop for office type stuff), so the components i've chosen are aimed towards games performance. I've also chosen parts that deal well with heat for overclockability, and have low noise output, just because I like things to be quiet. I'm don't plan on going SLi or CrossFire as i'd rather just keep upgrading a single card.
So, here's the spec i've picked out. I've already bought the RAM, and the rest will be bought in a few weeks time. I don't have a set budget, but i want to get the best bang-for-buck and not go overboard on high-end stuff for the sake of small performance gains.
E6750 Core2
OCZ 4GB (2x2GB) PC2-6400C4 800MHz Reaper HPC Enhanced Bandwidth Edition Dual Channel DDR2 (4-4-4-12)
MSI NX8800GT Zilent 512MB (Factory overcloked with Zalman Cooling solution)
NZXT Hush Silent Computer Chassis
Samsung Spinpoint HD501LJ 500GB SATA-II 16MB Cache (OEM)
Seasonic S12 II 500W PSU - 12cm Fan 80Plus Efficiency
ASUS P5K-E/WIFI-AP AiLifestyle Series P35 Socket 775 Socket eSATA
Writemaster SH-S203B/BEBN SATA DVD Drive
Cooler Master Hyper TX 2 Processor cooler
X-Fi Xtreme Music
Any thoughts or suggestions?
The E6750 is End of Life at the moment -- it has been replaced by the E8400. What were you intending to pay for the E6750? The E8400 runs cooler and OCs higher on average as it is a newer 45nm part, and it costs $200-220.
Why the ASUS board? They tend to be really overpriced for their featureset, and ASUS customer support isn't that great. I'd recommend the Abit IP35-Pro or Gigabyte P35-DS3R / DS4 / DQ6 instead. If you only need 4 SATA ports and don't need RAID, the Abit IP35-V / IP35-E and Gigabyte P35-DS3L overclock just as well as their more feature-rich brethren and can be had for ~$60.
Case is mostly personal preference, but there are better options from both a silence and cooling perfective than the Hush, and if you wait for a sale they may even cost less. The Antec P180 / P180B / P182 (same case, different color schemes) can be picked up for around $80 after rebate if you look around and wait a week or two. It has even gone down to $65 AR a few times. All that said, if you like the Hush there's really nothing wrong with it, so solid choice.
You might want to look around for deals on Corsair PSUs, as they can sometimes be found for less than the Seasonics AR and they're built for Corsair by Seasonic. Also as I understand the Corsair people are nicer to deal with should you ever have a problem. The Seasonic is great if you're getting a good price on it though.
The newer X-Fi Xtreme Music is a half height card, right? I'm reasonably sure you do /not/ want that card, as it does pretty much everything in software. I'd generally stay away from the X-Fis period unless you have some truly great speakers or headphones you'll be using; Realtek's onboard HD audio has come a long way, and it just keeps getting better with each driver update.
Well, I chose the E6750 because it does seem to be the best performing chip for the money. I was however unaware of the E8400's recent launch. I'd be tempted if it does run cooler and oc's higher as you claim, and that it also runs faster at stock.
I'm in the UK so prices are probably different to the US (double the prices I list to get the dollar equivelent). Over here I can get an E6750 for £116, or a Q6600 for £165. A new E8400 is listed at £129. Which would you say is worth it? The difference in benchmarks for the E6750 and Q6600 were around 3fps in games, which is not much of a gain in my opinion.
The particular Asus board has received loads of praise, and is apparently excellent for overclocking. I've had asus's in the past too and have had good experiences. I never use technical support so thats not too much of an issue.
I'll look into that case, but for £60, the hush seems good value for what i'd get. The reviews and appearance of the case are quite pleasing too.
The seasonic is £55, which seems a fair price. It's quite hard to get hold of the corsairs in the UK too.
I'm still undecided on the soundcard, as thats the area i havn't done too much research in. I did have the extreme music in a previous system though and it seemed perfect for both music and games.
The extra money for the E8400 over the E6750 is definitely worthwhile.
How long do you intend to go before your next major upgrade (new processor /and/ motherboard, as LGA775 will be replaced in about a year and no new chips released for it)? If more than about a year and a half, maybe two years, I'd strongly recommend you get the quad now, as /everything/ is going toward being multi-threaded, games included. The 'extra' two cores may not be used fully for six months to a year, but they will be more and more.
I saw some benchmarks for the E8400 and I completely agree that they're worth it for the extra money! I can't believe how much more performance you get out of the newer chips. I'll definately get one over an E6750, thanks for the heads up.
I'm intending to make this build last about a year or so, and then i'll stick with the same chipset but upgrade the processor/gfx card when needed. The next major upgrade won't be for at least 2 years probably. The E8400 will really suit me at the moment. I'll probably get a quad sometime in the future when it's worth it and eBay the dualcore.
As others have said, the E8400 is a no-brainer over the E6750. However, if you're near a Microcenter, the best deal on a processor at this moment is $200 for a G0 Q6600. Even though the E8400 can reach a higher OC on air, you can't add cores to it. A good air cooler will get a good Q6600 to 3.6ghz and a good E8400 to 4.0ghz. In most games today, the extra 400mhz (as well as the 5-10% E8400 performance benefit due to the die shrink) is negligible unless you plan to play games at ultra-low resolutions.
Umm, they don't have Microcenters in the UK where the OP resides, at least I don't think they have them right?
Hmm... I guessed I missed that. Sorry. I'm pretty sure they're not in the UK.
E6750 Core2
X-Fi Xtreme Music
CPU: Intel E8400
RAM: OK
3D: MSI 8800GT Quad Pipe cooling
PC Case: Look/Design is a personal opinion but I would go with a CoolerMaster CM690
HD: 74GB WD Raptor or Seagate SATA 7200.11 500GB Drive
Mobo: Gigabyte GA-P35-DS3L (if you don't want raid)
Cooler: Stock or ThermalRight Ultra 120mm cooler
Sound: Use onboard unless you've got a high-end pair of can or speaker.
Mouse: Logitech G9 or Razer Lachesis
Keyboard: Logitech G15 rev2
DVDRW: Samsung DVDRW
Everything looks fine. If you're going to buy an aftermarket cpu cooler, is there any reason why you're getting the Hyper TX? It's not loud and works fine, but the fan is not replaceable should it fail.
How do you mean it's not replaceable if it fails?
I chose it because it's cheap and provides a good amount of cooling and noise reduction, at least according to toms hardware's recent cooler reviews. It also just clips on, which in my opinion is a plus.
Regarding the soundcard, will onboard sound be sufficient to handle gaming well? I read a while ago that good modern cards help to lighten the load of the graphics cards/CPU by processing all the sound stuff.
I've never heard of Microcenters, so I don't think they are in the UK.
For a high OC, you'll want something better than the TX2. Though these links are for US sites, use them as references:
$35 - Scythe SCNJ-1100P Ninja Plus Rev.B CPU HSF (optional $7 Thermalright LGA775 Bolt-Thru-Kit; recommended if using w/ quadcore)
$45 - Tuniq Tower 120 CPU HSF
$46 - Thermalright Ultima 90 CPU HS + FBA09A12M - Z ($3)
$50 - ZEROtherm Nirvana NV120 120mm 2-ball UFO Bearing / Transparent CPU Cooler ($10 MIR)
$55 - Thermalright Ultra 120 eXtreme CPU HS + Scythe S-Flex Fan SFF21E ($15)
OnBoard sound should suffice. Onboard HD Audio has come a long way since onboard audio of the past. Modern CPUs are so powerful that onboard audio won't affect the CPU usage much... you'll probably lose 1-3fps, if any at all, during gaming.
