My first build by myself
wizzade
Ok....This will by my first build without help and i am wondering if it is going to work, and if so how well will it work. I would appreciate any suggestions. Thanks in advance.
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 2MB Cache E-IDE/ATAPI DVD Burner with LightScribe Technology - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16827106055
APEVIA X-Navigator ATXA8NW-BK/500 Black Aluminum ATX Mid Tower Computer Case 500W Power Supply - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16811144090
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16822148140
Creative 70SB046A00000 7.1 Channels 24-bit 192KHz PCI Interface Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16829102005
ASUS Commando LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
http://www.newegg.com/product/product.asp?item=N82E16813131149
Thermaltake CL-P0114 120mm CPU Cooler - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16835106061
EVGA 640-P2-N821-AR GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Video Card - Retail
http://www.newegg.com/product/Product.asp?item=N82E16814130071
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor - Retail
http://www.newegg.com/product/Product.asp?item=N82E16819115003
SCEPTRE X20WC-Gamer Black 20.1" 5ms DVI Widescreen Glare HD (HDCP) LCD Monitor 300 cd/m2 800:1 Built in Speakers - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16824112003
CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16820145168
Wow, don't use that power supply that comes with the case... Get something like a Corsair or OCZ
its already been said but don't use that PSU, Corsair 620w would be your best choice though there are other good choices.
Ok i will find a psu, any suggestions on brands or models......and how does the rest look
will this ram work with this motherboard?
srry if i am causing problems im kinda computer stupid
I concur. Get the Corsair 620HX 620W PSU. It's one of the best PSUs out there. If you want to save about $30 on that PSU, buy it from this site instead:
Corsair 620HX 620W PSU - $144
- Ditch that IDE DVD burner and go with an SATA model like this one if you want better airflow inside you case:
LITE-ON LH-20A1S 20X DVD±R DVD Burner SATA - $33
- Ditch that motherboard. Unless you need that firewire port or extra PCI-E x16 slot for a physics card, any of the two following mobos will be fine for you:
EVGA 122-CK-NF66-T1 NVIDIA nForce 650i Ultra Motherboard - $110
GIGABYTE GA-965P-DS3 Intel P965 Express Motherboard - $115
- Ditch that thermaltake CPU cooler. First of all it's sold out right now and second, there are better HSF out there. I recommend you get this CPU cooler:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185038
- Ditch that Domininator RAM. If you're planning to overclock, you can get away with using pretty cheap RAM to achieve a decent OC since you chose the E6600. Also, Dominator RAM is overpriced and really not worth it. Here's a decent RAM kit:
G.SKILL F2-6400CL5D-2GBNQ 2 x 1GB DDR2 800 RAM - $105
I concur with Danny and everyone else. Here are some other PSU suggestions: :cool:
http://www.jonnyguru.com/forums/showthread.php?t=1460
http://www.jonnyguru.com/forums/showthread.php?t=103
Also, do you really like that case? It uses 4x 80mm fans, so it may be a little loud. If you want a more quiet case, look for something that uses no 80mm fans, but at least 2x 120mm fans instead. Cases that come to mind are the Antec P180B, Thermaltake Armor Series (or Junior), Coolermaster Centurion 5 series (534 in particular) or Stacker Series, and Lian-Li PC-7.
Are you planning on running Vista? because Vista and the X-Fi don't play well together. Vista called X-Fi useles, and X-Fi can't come up with a retort.
