The first thing I told myself I was going to buy when I graduated college and found a job was a nice PC. Well that time has finally come. Now, I have already ordered this, so I don't expect to change it(yeah I was too anxious), unless I screwed something up of course.
My case and PSU are the only parts I am trying to re-use. I do have a quick question though. I have a 9800GTX+ that will be sitting around. I want to toss that in with the build to run as a physx card per this thread http://www.hardforum.com/showthread.php?t=1456964. Would my PSU be able to handle that? Or should I be safe and buy a new PSU? I believe it will be okay from checking PSU calculators. Also, what PCI-E slot do I throw the 9800 into for the Physx?
Side Note: I play a lot of games online. That is what this computer is going to be for. I decided to buy a cooler for the hell of it. I don't plan on OCing right away, but maybe after 6months/1year I plan on it. Most of the parts that I decided to buy were from lurking on these forums and reading what you guys have had to say. Thanks by the way and always love reading these forums.
Monitor - http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
CPU(i7 920)- http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
HDD(WD 1TB Caviar Black) - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
GPU (ATI 5870)- http://www.newegg.com/Product/Product.aspx?Item=N82E16814121345
RAM (6GB G.SKILL) - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
Mobo (Gigabyte UD5) - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128362
PSU (Corsair 650TX) - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Case (Antec 900)- http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
Cooler (Cogage True Spirit) - http://www.frozencpu.com/products/9403/cpu-tri-62/Thermalright_CoGage_True_Spirit_4-Heatpipe_Core_i7_CPU_Cooler_Socket_LGA_1156_LGA_1366.html
