My E6600, DQ6 overclocking results.
50Stang
Here are my results with my E6600 and Gigabyte DQ6 motherboard with two 512mb sticks of DDR2-533. The only thing that has me concerned is the temperatures under load with core temp are 72° C but on idle its 52° C, speedfan never puts it over 40° C..can someone verify if these are safe temps or correct temps with core temp program.
I have not gotten any errors, and orthose ran for over 9 hours without fault. This is with the stock heatsink/fan.. do I need a better one ?
Well I got a very similar setup as you, cept I got a Zalman 9500 cooler.
I can do 3.2/3.4 stable @ 1.3825/1.4 with temps in core temp under load <60 (at 3.2 its around 52-54 and at 3.4 its at 57-59)
You need better cooling.
Oh and also, the gigabyte tool never goes over 40c on the socket.
InorganicMatter said:
Lame! Let's see 3.2GHz!!!!!
It will do 3.15ghz.. I just didn't want to push it until I knew it was going to be Orthos safe at 2.92ghz.
Post above me: I'm glad to hear that, my EasyTune software restarts the computer everytime I try to load it.. only software that does it, even at non-oc speed.
Core temp is the most accurate temp reading software I've ever found. YOUR CPU IS HOT :eek: Buy a better cooler (scythe infinity, etc..) then continue to OC. With your E6600 and a 9 multi, you should hit 3.3+Ghz with ease, depending on your ram of course.
Thanks for the information, I just ordered a Zalman 9500 AT 2 Cooler.. they were on sale at newegg for like $47 + ship and rush process.
Is it difficult to install ?? This setup is the first 775 I have ever dealt with. Is it as easy as the stock hs/fan or do I have to remove some stuff to put new brackets on for the new hs/fan ?
Yup, you might have to remove the motherboard from your case, although since were on this type of forum, we love to do this stuff :p . You should see some great temps now.....
i don't have Zalman 9500, but you might have to take out our mobo from your casing to install the heatsink. and most probably , the new heatsink would come with its own brackets which you have to use.
Definately. I do it all day at work also. It is routine!
I am really beginning not to believe Core Temp.. at stock speed, it says my idle temp is 50° C, and load with Orthos is 60° C
With EasyTune, my idle temp is 33° C, and under load its 45-48° C.
Seems like with other results compared, my EasyTune software is more accurate.
Plumber4life said:
you will have modify that heatsink for sure because of the back plate but will work
I'm sorry, but how do you mean modify ? Like taking the heatsink thats on the back of the motherboard off ? It isn't just a regular bolt on ?
If easytune5 was accurate, then im idling @ 21-22c and loading @ 29c :D I wish that was right. Then I found core temp, and BOOM 40-41c idle, and 52c loaded
You will have to remove your mobo and remove the "Crazy Cool" backplate. Wasn't hard for me, just unscrew/squeeze these plastic cap thingys (sorry, not sure what to call em)
After that, its just following the instuctions that come with it (put on backplate, put on retention frame thingy, screw down)
works a dream for me.
newls1 said:
I think I pretty much said the same thing ;)
yup! u did. sorry! didn't notice ur post, cuz i was typing mine while u posted yours. :)
Ok cool, thats what I needed to know. I've been working with computers for a long time but I have never touched a socket 775 board/cpu. At work we have always sold AMD until now.
I'm sure you can find a decent HSF that uses the regular retention clips. I use an Arctic Cooling Freezer 7 Pro myself and it works fine. Not as good as something with a back plate like a TT Big Typhoon, but decent enough for me. I can get a 6600 to 3.2Ghz.
so did you try that clock with a little bit less juice? (vcore)
Maybe shoot for 3Ghz. Nice round number 9x333, and then you can enable EIST for when you're idle it will run at 6x333 = 2Ghz and run really cool. It will make a HUGE difference in your average computing.
http://www.crowdcontrolusa.com/overclock/shizzy3.html
Thats what I have my computer set at, and when I'm doing average stuff like surfing, email, etc... it stays at 2Ghz most of the time, except maybe when a new page first loads, it will jump to 3Ghz for a second or 2 then drop back down. The temps stay like 34C, full load I'm around 60C. Voltage is set to 1.375 in the BIOS, which actually reads lower in windows under load (vdroop).
This is exactly what I do also. Great computing experience.
Wow, I enabled that feature to full thrust.. and when it needs it, right now it shoots up to 2.7ghz. I suppose it will change when I manually change the speed in the bios and the multiplys by 17% or so.
Badass feature!
For most people with overclocked 6600/6700/6800's, EIST is a must have on feature!! It drops your temps & power consumption dramatically when idle. And when you need the "horsepower" it kicks right in, INSTANTLY, so there's virtually no point in not enabling.
with overclocked 6300/6400's most people can't use EIST, b/c the drop in voltage would cause instability.
I got my Zalman 9500 AT in today.. it looks like a beast, cannot wait to install it!
Maybe I have done something wrong ? I have the Zalman 9500 AT installed now, and at 3ghz.. core temp reads 63°C
I have a ThermalTake mambo case, and three 120mm fans (front, back and side).. I haven't really seen any difference.
Any suggestions on how to get this thing cooler ?
Gigabyte EASYTUNE 5 puts it at 55° C... which one to believe!! argh
63C is fine for a CoreTemp reading.
Mine is right around 60C under load, with a Thermalright XP-90c.
Case/ Airflow has a lot to do with temps too. Ideally you want fresh air blowing in to your heatsink and the exhaust air blowing out of the case.
Thats why so many people have good results with the Scythe HSF's.
B/c the fan can be oriented to blow the exhaust air towards the back of the case & exit. And the fresh / cool air from the front of the case is aimed at the HSF's intake.
Easytune/ Speed fan temps are comparable to results you've seen in the past. CoreTemp (Core2) read the temps from a place directly on each CPU, so the temps read higher. In fact there have been some people with CoreTemp readings of 70C+ and there system was still stable. Though I'd prefer to keep my temps lower. like CoreTemp 65C or less, Speedfan <=60C
My system was fine with my stock heatsink at 3.15ghz on stock hs/fan and it was reading 72°C.. but it doesnt go higher than 65° now at that speed.
The Zalman 9500 blows exhaust directly out the back as well... its a very nice hs/fan.
My memory starts hating me at 350 though.
