GreenGoose
- Aug 17, 2004
I built a small system in February 2010 with the DFI MI P55-T36, i5-750, HIS HD 5450, Corsair XMS 3 memory, and an Antec BP550 modular power supply. I chose the Lian Li PC-Q07 case. I knew this case had poor airflow; however, I didn't plan on overclocking, gaming, or anything else very strenuous so I thought it would be fine. This build was just a small internet surfer and office machine.
Yesterday evening, I was on the internet looking around on the internet when I smelled an electrical fire smell then heard a "pop". The machine stopped immediately. I quickly turned the case around and looked through the small vents and observed a flame! It was like a Bic lighter was burning on my motherboard. I took the side panel off and managed to blow it out, lol! I took the power supply out and observed it was still smoldering so out in the backyard it went.
It appears the fire started around a capacitor near the P55 chip. Photos below.
Anyway, I thought I would pass this along. The P55 chip on this motherboard does need a lot of airflow regardless of what you are doing. I think I will replace it with a Gigabyte GA-H55N-USB3. Do you think airflow will be a factor on this board as well? Or should I just keep a fire extinguisher close? I'm trying to figure out how to rig a fan up but there is zero space inside.
