Randominal
- Jan 14, 2007
Well after trying to transplant my old dell dimension into a new case i found my computer stopped working. Now when i try to switch on the computer the power and HDD LEDs switch on and the power LED on the mother board also switches on however nothing else does and the motherboard does not even post i have looked at the diagnosis LEDs at the back panel and the manual says that this means a pre bios error has occured. I am not sure which component is causing the problem however as it may be the PSU, the mobo or even perhaps the CPU (i very much doubt this is the problem - but its still possible).
During the moving of components from one case to the other i did drop the psu and now it seems to make a bit more noise than it used to. However like i said the power LEDs come on so i am not sure whether it is in fact broken. Also i am pretty much sure all the power cables are plugged in correctly.
so how which do you think is causing the roblem and does it need to be replaced?
