My computer beeps the regular 1 beep, but no POST!
Ok, well, today my computer started acting funny by shutting itself off several times (not by windows shut down, I mean automatic power off), which lead to me to reseat the 12v 20 and 4 pin connectors several times...
Now though, what happens now is that it starts it beeps and starts its usual boot up to the start up screen (for the mobo), but then it never gets to turn on the monitor to show the startup screen... It just reboots over and over, starting the dvd burner like it should, and then reboot, reboot, reboot, reboot... a cyclic reboot. So now I cannot get into bios, nor do I see anything on the screen... I've tried reseating the cpu, video card, ram, clearing cmos (battery and pin), changing ports on IDE and SATA, booting off of 1 hard drive, and none, but it just doesn't boot... Just tried a bios flash recovery, failed. Cleared cmos overnight, failed...
I've unplugged everything too, it still failed... No spare psu to use...
What would you say is the cause? Any possibilities of it being fixed?
RMA?
Any other suggestions before I RMA?
I have
enermax 485w noisetaker
MSI K8N Neo2 Motherboard
eVGA 6800 ultra
1 GB Corsair 4400c25
nec nd2510a
floppy
audigy 2 zs
amd 64 3200+ venice 90nm
well for starters POST = Power On Self Test
and equals one beep in most BIOS beep codes
what it sounds like is a bad component but youd need to start swapping components to find it
Id strip it down to just the CPU\HSF mobo and speaker, if you get the single beep add a different vidcard and try for BIOS
could be you have a thermal cutout in play here
verify the HSF is attached to the proper mobo header and working
and that the HS is properly mounted
Hum... I did boot with the bare necessities, nothing worked.
Reseated my cpu and heatsink again, nope.
Trying to find another video card.
lets try this one more time
how many beeps when you did that?
you verified the mobo header and eliminated the thermal cutout at the mobo header as the cause ?
if you are getting a single beep youre passing post and the fault lies elsewhere
Just 1 short beep.
Yes I checked the thermal cutout, all fine....
So if my mobo actually beeps, but messed up D-LED, is it time to blame my power supply or what?
Have your tried a different power supply.... I had a friend that something similiar happened to because his 450W PSU wasn't supplying enough apms on the 12v rail...
Id try another PSU and Id try another vid card in VGA compatibility
its possible the BIOS is corrupted but if it is passing POST I wouldn't think that is it
http://www.bioscentral.com/postcodes/awardbios.htm
"typical" POST test
AWARD Test Sequence after version 4.2:
CPU BIOS sets, verifies and resets the error flags in the CPU then performs a register test by writing and reading bit patterns. Failure is normally due to the CPU or clock chip
Initialize Support Chips Video is disabled as is parity, DMA and NMI. Then the PIT, PIC, and DMA chips are initialized. Failure is normally the DMA or PIT chips
Initialize Keyboard Keyboard and controller are initialized
ROM BIOS Test A checksum is performed by the ROM BIOS on the data within itself and is compared to a preset value of 00. Failure is normally due tot he ROM BIOS
CMOS Test A test of the CMOS chip which should also detect a bad battery. Failure is due to either the CMOS chip or the battery
Memory Test First 356K of memory tested with any routines in the chipsets. Failure is normally due to defective memory
Cache Initialization Any external cache to the chipset in activated. Failure is normally due to the cache controller or chips
Initialize Vector Table Interrupt vectors are initialized and the interrupt table is installed into low memory. Failure is normally due to the BIOS or low memory
CMOS RAM CMOS RAM checksum tested and BIOS defaults loaded if invalid. Failure would indicate CMOS RAM failure
Keyboard Initialization Keyboard initialized and Num Lock set on. Check the keyboard or controller is a failure occurs
Video Test Video adapter tested and initialized
Video Memory Tested for Mono and CGA adapters. Failure could be the adapter card
DMA Test DMA controllers and page registers are tested. Failure could indicate bad DMA chips
PIC Tests 8259 PIC chips are tested. Failure would indicate a bad PIC
EISA Mode Test A checksum is performed on the extended data area of CMOS where EISA information is stored. If passed the EISA adapter is initialized
Enable Slots Slots 0-15 doe EISA adapters are enabled if the above test is passed
Memory Size Memory addresses above 256K written in 64K blocks and addresses found are initialized. If a bit is bad, the entire block containing it and those above will not be seen
Memory Test Read and write tests are performed on memory above 256K. Failure is due to bad bit in RAM
EISA Memory Memory tests on any adapters initialize previously. Check the memory chips if a failure occurs
Mouse Initialization Checks for a mouse and installs the appropriate interrupt vectors if one is found. Check the mouse adapter if a failure occurs
Cache Initialized The cache controller is initialized if present
Shadow RAM Setup Any Shadow RAM present according to the CMOS is enabled
Floppy Test Test and initialize floppy controller and drive
Hard Drive Test Test and initialize hard disk controller and drive. You may have an improper setup or a bad controller/hard drive if a failure occurs
Serial and Parallel Ports Amy serial and parallel ports are found and initialized
Math Coprocessor The coprocessor is initialized if found. Check the CMOS setup or the math coprocessor if a failure occurs
Boot Speed Set the default speed at which the computer boots
POST Loop Reboot occurs if the loop pin is set for manufacturing purposes
Security Ask for a password if one has been set in the CMOS.
Write CMOS The BIOS is waiting to write the CMOS values from Setup to CMOS RAM. Failure is normally due to an invalid CMOS configuration
Pre-Boot The BIOS is waiting to to write the CMOS values from Setup to CMOS RAM
Adapter ROM Initialization Adapter ROM's between C800 and EFFF are Initialized. The ROM will do an internal test before giving back control to the system ROM. Failure is normally due to the adapter ROM or the adapter card
Setup Time Set CMOS time to the value located at 40h of the BIOS data area
Boot System Control is given to Int 19 boot loader
Have you reset the CMOS???? My vote is still for the PSU though... It might not be giving enough power to the vid card...
yes I have reset CMOS.
Well later on this week I'm going to test it with a different video card and psu.
OK update... Tried different ram and power supply, still a POS...
Video card is fine.
RMA the mobo?
I swear there are no shorts either.
does the d bracket got through ALL of its sequences? i dont know how many times its saved my butt.
i think it may just be your mobo being a bitch. mine is being a bitch on and off...
Get a new CMOS battery. Believe it or not, this has fixed problems for me more than once.
No, it just boots straight up orange, red, red, orange... Orange can also be yellow...
As for the new CMOS battery, if you guys believe its the mobo, I'll just send it in since its still under warranty.
Plus, my floppy disk drive can't write, but it can read, so bleh.
AzNIronclad said:
Wt..
It's on putfile.
It's an avi I stuck on putfile.
uhh :)
no its forcing me to install WMP
1. Ive ripped WMP out of this box (even the default version)
2. Ive ripped IE out of this box
3. I employ Quicktime alternative not Quicktime
if you have an FTP where I can download the avi I can view it no problem with Classic Media Player, but no I wont be installing that junk on my computer just to watch this vid ;)
the fact they force that crap down your throat is the height of irony considering those are Linux servers they are running :rolleyes:
