My case is missing the rails for HDDs...Alternative?
SomeGuy133
This computer I bought off craigslist and It didn't come with rails. I assumed you could just use screws but I assumed wrong. I haven't been able to find a way to buy them online so whats an alternative? I am not concerned about them moving in the case because its stationary but I am concerned about other things:
Shorting
heat
static
or anything else.
I assume its ill advised to just stack them on top of each other while running so what would be a valid material to space them so that they won't catch on fire, short them, or anything else?
I still have to see if maybe I can use super long screws to hold them in place but I am doubtful on that working/working well.
I am also open to the idea of a homemade external enclosure if its not a lot of work. I'll just run the cables outside of the case.
Also I am using 6-8 drives.
I do plan on buying a new case down the road so this is temporary. I do not want to buy a new case now since I do not know what my new computer will look like.
If you don't mind a ghetto mod you can always use spacers made of wood or plastic between the drive and the sides of the drive enclosure. Fasten drive to spacer and then screw spacer into the sides.
is wood safe to use? I was afraid of some component reaching 250F/122 C. IIRC thats the typical temp that wood ignites. I know some components can reach that high like regulators and caps.
The plastic I thought was a good idea as long as it doesn't melt. Some are better than others and I got to get the right size. Have any experience with that?
could I just space them with plexi glass? That would be thin and easy to cut. I could also make it where it doesn't block air flow.
Wood would be safe. If you have a hard drive getting anywhere near that hot, your computer is probably already on fire. Acrylic or plexi would probably be preferable- if you're drilling holes in a very thin sheet of material (you'll probably be using short screws), wood is less robust. I've done what you're talking about with acrylic and it worked out fine, despite looking ghetto.
There's also always the 3D printed route. Just searching "hard drive" on Thingiverse turned up quite a few options without you having to even do any modeling, and this one looks like a good start- http://www.thingiverse.com/thing:806825
where can you print stuff?
EDIT: sweet UPS has a store about 30 mins away that prints :)
contact raidmax support and buy the missing parts?
if you posted the make and model of the case it would be easier for us to give suggestions too.
Um...what?
The auto ignition temperature of wood is several hundred degrees. For example, dry pine wood requires 427C or 800F.
Yea sorry I have no idea what case it is. It is a raidmax case. I don't see any name on it unless it is hidden.
https://www.dropbox.com/s/6f9weddfczcwa4x/2015-07-08 16.10.27.jpg?dl=0
those are the rails.
I am ok with that external thing because the case is retarded. It has the drives going across the case for easy access but the problem is the case is so narrow the SATA cable gets super bent -_-
Even using the 90 degree cables it has issues. So the outside case option actually sounds like a good idea.
Um...what?
not from my research dry wood starts at 250 F or it could have been 250 C but i am pretty sure its 250 F.
Reason why i know this is because my father in law uses wood burners and i researched how hot wood has to get and it was 250 F or C but i am pretty sure it was F. Thats what i read from the sources I found. His walls were pushing 200 or higher next to the stove. He had wood like an idiot near the stove drying and it caught on fire while I was sleeping. whole house was filled with smoke.
https://www.dropbox.com/s/avd265wf67hqttc/2014-01-24 13.22.07.jpg?dl=0
dumbass -_-
i bought a computer off a guy that had this raidmax case
Yeah that's not a good sign of the quality of that system. What's the specs of the rest of the PC?
I've had the unfortunate luck to work a lot of different Raidmax cases in the past few years. Post a picture of the case itself and we can probably figure it out from there.
Though since it's a Raidmax, I would just replace it anyway ASAP. I've never once seen or worked with a Raidmax case that I would consider "good". I recommend this case as a significantly better case for your file server usage:
$55 - NZXT Source 210 Elite White with Black Front Trim ATX Case
I plan on getting a norco 4224 for my NAS and getting a new case but not sure if I am going X99. I want to get the largest case possible...don't care if its 300 as long as its huge but I can't get that til a month or two.
Looks just liek this. It has all the features of a good case but just too small to fit them all lol
http://www.avadirect.com/Cobra-Black-Mid-Tower-Case-ATX-No-PSU-Steel-Plastic/Product/7544036
I paid like 600 or something for it:
4770K
cheap AIO cooler
GTX 770
16 GB of ram
MB (which I broke lol but now i got a good MB)
BD drive
PSU
maybe something else
It was much cheaper than buying new and best deal on craigslist. The CPU, GPU, and RAM were like worth about how much I paid for the whole thing so everything else was like free :)
People like to buy shit MB and cases and PSUs...why. Oh and fill all 4 slots with low capacity ram but this one didn't have that at least :)
Even if it was larger, it still wouldn't be a good case.
How were you planning on cramming in six hard drives into that thing when it can only fit three?
it can fit like 8. There are 2 areas for drives but like I said an external solution is actually a great Idea. I think I'll print 2 towers. My dad said he has a 3D printer at work so I'll see if I can get it for free :)
The 2.5 in is adjustable to 3.5 so there is 7 but 8 if you just drop a loose drive in bottom.
If that's the exact case you have, Raidmax themselves says that case only fits three 3.5" HDD:
http://www.raidmax.com/cobra-z.html
Unless you're also planning using 2.5" hard drives or literally stacking them on top of each in the dumbest way possible, I'm not seeing 8 hard drive here.
If the external solution costs more than $30, it's a ripoff since you can just buy a whole new case for $50 that supports 8 hard drives.
EDIT: Why would you use 2.5' drives for storage in a file server in the first place? The price per storage on those are bad. But I do see what you mean about the adjustable bay.
dumbass -_-
250C sounds more appropriate. That's 482 degrees Fahrenheit. Cellulose paper made from wood supposedly auto ignites at 233C=451 degrees F, give or take a few dozen degrees F depending on paper type. Most wood takes much more heat than that, especially depending on the thickness and type. This site quotes 300C for wood, so the values really are all over the place.
But all that argument really doesn't matter. As someone else stated, even 250F is obscene, and if you were seeing 250F inside the case it was likely already on fire and the temperature was about to skyrocket much higher. I also have never seen an individual computer component get near 120c or approx 250f. I've only seen a few hit 105c before shutting down completely.
sorry made an edit. The 2.5s can be changed to 3.5s. You can unscrew and move the spacers to fit 3.5s.
Some VRMs and CAPs hit 120+ C (some even 140-150 IIRC) but again if a single component can get 10-20C away from igniting it...why play with fire if a different and easier material exists? no reason
Again I rather not be my father in law and be an idiot and take pointless chances.
oh my fucking god when i see threads like this all i can think is i so want a 3d printer!!
i know i want one too but many things would have to come first lol. I have so few things lol. a car and PC is literally everything I own -_- I don't even have any guns yet or a progressive press lol. Waiting to see if my dad can print it at work or if i have to hit up UPS. He said he will let me know by Friday so I'll post back with pictures whenever I get it and let you guys know how it works.
You can get a Da Vinci 1.0 on sale for $350 on Newegg from time to time. I have one, and it's fantastic for the money- 8x8x8" build volume, support for ABS or PLA, and a heated build platform. It still has the typical pain in the ass problems of any 3D printer (bed leveling takes a while, cleaning is unavoidable), but it's quite good overall. Plus it's very hackable, if you don't like their proprietary filaments or software (which are both fine, IMHO).
im thinking of it but the main reason is because it seems like a cool toy lol. SomeGuy133: dude, must gun first! :D
Judging from the Newegg reviews, doesn't seem like a solid buy.
Mostly noobs bitching about support and 3D printing still being a less mature process. Of the whole 3D printer category on Newegg, here's how the customer ratings break out:
It's an early adopter technology that's been massively oversold by corporate interests, so this isn't too surprising.
Looking on Amazon, the Da Vinci 1.0 has an average 3.5 stars from 512 reviews, versus the $2,800 Makerbot 5th Gen's 4 stars. The earlier (and still comparable) $2000 Makerbot Replicator 2 has 108 reviews, averaging 3.5 stars.
The Makerbot lacks a heated build plate, which means it will have trouble printing ABS plastic. PLA (the MakerBot's standard filament) is not as sturdy as ABS, and has a much lower melting point. Build volume is comparable to the Da Vinci. The new 5th gen model is the subject of a class action lawsuit related to their expensive extruders constantly crapping out.
The resolution and print quality of the MakerBot, of course, are excellent.
If you're starting 3D printing on the cheap, you'd be hard-pressed to do better than the Da Vinci. Most other options in this range lack a heated built plate, don't have enclosed build areas, and have smaller build volumes. I care more about ABS and build size than resolution- I mostly use mine for various crazy maker projects (e.g., robots that shoot fire, robots that shoot rockets, robots that make children cry), so a heated build plate was a no-brainer.
As for CAD, I was intimidated at first, but it's not terribly difficult. There are a huge number of tools at this point- both visual, and command line driven. You'll find what's intuitive for you as you go. Meanwhile, you can start off by remixing and editing stuff you find on Thingiverse. At this point, I've settled on OpenSCAD for most of what I do. Also, a set of cheap ($10-15) digital calipers is essential for measuring.. anything you want to interface with.
Edit: nice rundown of some of the top options: http://bestreviews.com/5-best-3d-pr...position=1t3&gclid=CIHrlZiS38YCFUyPHwod0WEMHQ
