Will start with the basics
Gaming
I'd like to stay within the ranges of my current build (cheaper or lets say like $30ish additional bucks per part)
3) Where do you live?
CT, USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
I do not need any additional parts than the ones listed below (just edits to those parts)
n/a
6) Will you be overclocking?
Either no or very lightly.
24" 19k x 10k
Within 2 months of July 14th
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
eSATA, Sata3+6, USB 3.0 are nearly mandatory unless I can get a sata6/usb3.0 pci card in there
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
64bit Win7 Pro
Here is my build so far (not bought yet)
CPU: i7-930 ($200)
MOBO: Apparently I am silly and picked an incompatible mobo, so please any 150 dollarish i7-930 compat mobo suggestions would be appreciated($150)
Video: EVGA GTX 460 1GB or Radeon HD5830 (just 1 of either, I'm not sure which is best?) ($200)
PSU: 550w Corsair modular (reused, not too concerned about this part if my system needs more juice)
RAM: DDR3 1600 (insert reputable manufacturer here) 4GB for $60-80 or perhaps 6GB for $100-120
Case: Antec 902 - ($80)
The links are more for spec comparing/viewing, the prices I list may not not be what the link prices are but I will get them at or below the prices I have listed (in brand new condition) so just go off that price standpoint.
I guess if anyone can suggest a part such as a case that performs equally well at a better price or just works better in general with the rest of the build that would be quite helpful
Gaming
CT, USA
n/a
24" 19k x 10k
64bit Win7 Pro
CPU: i7-930 ($200)
