My build - any comments/concerns/compliments?
hwJunkie
gaming pc
cpu: i5-2500k
gpu: asus 6970
ram: 8GB DDR3-1600 GSKill
mobo: MSI P67A-C43
ssd: 128GB crucial m4
hd: 1TB WD
psu: corsair hx650
monitors: Asus VH238H (x2)
case: storm scout
hsf: Hyper 212+
mouse: logitech g500
mouse feet: XTRAC PADS Mad Dotz, logitech replacement feet
pad: XTRAC PADS Ripper (x2)
keyboard: Logitech 920-000914 Black
sound card: asus xonar dg
headset: sennheiser pc161
dvdrw: ASUS
fan controller: nzxt 5 port mesh front
fans: 3 x 120mm, 2 x 140mm
fan filters: 2 for side intake
-is there some ssd to hd fitting adapter i need to fit the 2.5" m4
price comes out to ~$2300
Looks pretty solid - where are you getting it, because $2300 seems high (unless those are expensive monitors). Is that a WD Caviar Green 1TB, or Black? If Black, you can check out the Samsung F3 instead, it is a few dollars cheaper with equal or greater performance.
Do not got the storm scout.. The case is a bitch. HAF 912 or CM 690. Also a [URL="Dell u2311]http://www.amazon.com/Dell-UltraSharp-U2311H-Widescreen-DisplayPort/dp/B003QTKV9W[/URL] would look a lot better
Where are you buying the parts from? What parts do you have already?
I don't know about the Storm Scout or the HAF 912, but the CM690 II Advanced includes an SSD adapter as part of the package.
one order from directcanada.com and one order from newegg.ca
I have to get the black it fits in my order better
Do not got the storm scout.. The case is a bitch. HAF 912 or CM 690. Also a Where are you buying the parts from? What parts do you have already?
I know now the storm scout comes with an adapter.
Gaming
Budget isn`t set, but needs to be reasonable, currently around $2300.
Canada
Everything (that I listed :p)
6) Will you be overclocking?
yes, oc cpu to around 4.4ghz
around 23 at 1080p
very soon, within the week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
no CF, firewire, raid, onboardvideo. I need Sata 6GBs for the ssd, usb3.0 is optional
windows 7 ult x64
I recently had a long discussion on what case to get and determined the storm scout was the best for me. A windowed, well ventilated, dust controlled case for $100.
Do you honestly need a windowed case to the point that an inferior case is worth it? Ia sk because the Storm Scout is cramped and has really shitty cable management. Why show off that? The Corsair Carbide 400R actually costs about the same than Storm Scout but has a whole bunch of features that the Storm Scout doesn't have:
- USB 3.0 front panel
- Significantly better cable management
- Roomier
- Backed by a two year warranty
- Costs roughly the same:
http://www.directcanada.com/products/?sku=11180AC6193&vpn=CC-9011011-WW&manufacture=CORSAIR
Anyway, the CPU, mobo, RAM, SSD, HDD, PSU, and HSF choices looks fine to me.
- Roomier
You are offering me things that I do not need.
I have a modular PSU for cable management, don`t care about usb that much, why would i just want extra room, warranty for 2 years i don`t care, no window
if i were going with a windowless case I would get it, but you`re just saying, why not go with something you don`t want
answer: because i don`t want it
Still not gonna help since it'll still be hard to route and/or hide the cables you have to use to for the PC.
Makes it easier to work inside the case as well as able to fit parts better.
So you want a cramped case with shitty cable management with a window? Fine, go for the Storm Scout. At the end of the day, it's your money and your problem.
But like I said earlier, the CPU, mobo, RAM, SSD, HDD, PSU, and HSF choices looks fine to me.
Lol
A cramped case, with shitty cable management, a window, good ventilation and dust control, yes I'm happy about that :D
I concur Danny's recommendation on the case. Cramped cases suck.
weeew cramped cases suck
good thing i only build my computer once and don't open my computer and rearrange things everyday
Here's the deal:
Cases that are cramped from rear to front restrict the length of the graphics cards that you can install in a case. Some cases are so cramped from rear to front that a mid-range GPU (graphics card) with a length of 9 inches can barely fit inside without being blocked by the hard drive(s) or even the case's nonremovable drive cage bracket.
so would you happen to know if a Sapphire 6950 with an Asrock Extreme3 Gen3 mobo would fit in a storm scout? just randomly guess off the top of your head
The Storm Scout has a max GPU length of 10.6". A reference HD 6950 2GB and HD 6970 2GB card has a length of 10.75".
As Danny noted, the HD 6950 will not fit the Storm Scout case. And even an HD 6800 series is a tight squeeze inside the Storm Scout, especially with a hard drive installed in the bay that's inline with the PCI-e x16 slot.
Lol... holy fuck i almost made an annoying mistake
WELP time to find a new case from square one again
YAAAAAAAY
Guess I forgot to add one requirement for my case.
Windowed, well ventilated, dust filtered, and able to fit Sapphire 6950, for $100 price point.
If that does not exist, I will get one without a window.
Look at the Lian Li Lancool PC-K58W and PC-K62 cases
dan thx the PC-K62 looks amazing
but i don't know if it will fit a hyper 212 evo?
lol hmmmm.... is it possible to install the hyper evo sideways? not sure how to interpret this newegg comment,
" It fits a CM Hyper 212+ easily (width wise, check pci-e height on your mobo to ensure it would fit vertically."
also i like how it can fit ssds
I have the storm scout and the Sapphire HD6850 (product dimension is listed at 14.8 x 9.8 x 4 inches), it fits nicely in my case.
The Sapphire 6950 you've mentioned have the same dimension as the Sapphire HD6850. So, I don't see any reason why it wont fit.
Yes, I agree that the case is a bit cramp, but that didn't really bother me, as like you, I don't intend to take it apart once it's built. I like this case actually. Just the right size, it's quiet, and it looks good.
well i would actually change my mind anyway and get this lancool k62 because it looks amazing
i like the fact it has good airflow without making a duct in the window
also i will have to assume it will fit the hyper 212 evo
thx going with lancool k62
