My BFG ES-800 failed after 2 weeks
I turned it on today and it emitted this horrible screeching/whining noise. I have tried contacting BFG technical support several times, but have remained on hold indefinately, the longest being for 30 minutes. :mad:
BFG claims that they are available 24/7 365, but from my experience, this is doubtful.
I'll probably run out to Fry's tomorrow and purchase a Corsair unit, because at least I know their customer support is good.
sounds like a voltage alarm.
I'd give every power connection a jiggle before going out and grabbing a new unit if I were you.
Well, I finally got through to BFG tech support, and it's a bad fan. I'm RMAing it tomorrow. I'm back on my old Silverstone unit, and damn is this thing loud. Much better than dropping $100 on a PSU for a few days, though.
I had to re-install windows, and that seems odd. I've never had that happen before. When I finally got my old PSU hooked back up and booted, my motherboard said "BOOTMGR is missing".
Something else is afoot...
Yeah, well... it was spinning up when the PSU started screaming. I freaked out and pulled the plug immediately. It could have been in the middle of a write.
No harm, no foul, as I've got everything installed again now.
that would do it....
Run the manufacturers test software on the drive to be sure.
I've already formatted the drive as it was my boot drive, but I'll do that next time (I hope there is no "next time").
This thing was scary loud though. I though a capacitor was going or something.
I think he means to run the test software on the drive so you know the drive's OK :), not to see if there are data errors. It's worth taking a couple minutes to do.
