- Dec 19, 2005
why? heard its for 300+ WDude, use both CPU power cables, lol.
More ground wires, spreads the load even if you don't use full 300wwhy? heard its for 300+ W
load on PSU or mobo VRMs?More ground wires, spreads the load even if you don't use full 300w
That doesn’t really matter. Each of the those EPS 8pin cables are rated to deliver 300-380w power. You can easily and without issue run most if not all modern CPUs on a single 8 pin cable. It’s only for serious overclocking that you actually need to use both cables. Most motherboards have 2 8pin cables for redundancy and to slightly lower the temps of each connector. With a 9800X3D only really drawing 150-160w of power at full load he was in no danger of even getting close to the capacity of a single cable much less 2 of them.Dude, use both CPU power cables, lol.
Cables and connectors, don't think it makes much difference for psu or vrms. Although maybe it helps certain vrm designs at high load.load on PSU or mobo VRMs?
The worrying thing for me is how the vcore vid max voltages spike into the 1.45s by default. Which was what killed the 14900ks etc although I think the Intel chips were a little more "generous" on the voltage spikes prior to all the latest BIOS fix patches but the ryzens are pretty high up too imo.I hope this doesn't become a 9800X3D issue like Intel's 13th and 14th gen. I've heard and read rumblings.
I mean, sure, just use one CPU power cable when there's two CPU power plugs. I just take the side of caution since I don't own any design schematics on how the power delivery works for the motherboard. Maybe there's load balancing, maybe there's more stability, maybe maybe maybe...why? heard its for 300+ W
You big mad, huh? Sorry I ruined your world view with my lived experiences. Hugs.You are talking about a "game" in alpha, allow me to LOL
Swapping out the motherboard is an option. Is it a good one? Yes if you have the cash to burn and moreso to have extra parts for troubleshooting in the future.thinking about this motherboard if i have to,
https://wccftech.com/review/msi-mpg-x870e-carbon-max-wifi-motherboard-review-maxing-out-carbon/
Latest BIOS
VID can be ignored if the Vcore is between the correct margin, VID can have very high spikes even on idle and mean nothing, vid is the voltage identificator requested by the CPU to the motherboard, but not necessarily what the CPU is receiving, before that is applied vdroop and LLC and the CPU receive the applied voltage. and the Vcore at 1.392 without any manual adjustment isn't bad for those cpus.
I suppose it's a divided crowd. Some users are ok with the vcore voltage kissing 1.4v, and some are definitely more comfortable keeping it below 1.3v somewhere in the 1.275v range. Also not sure if the juice is worth the squeeze for that extra 100 or 200 mhz. The 9850X3D is already receiving harsh criticism of how unimpressive and unnecessary boosting the voltage and power consumption up higher for a couple percent % of fps in the best cases. Not to mention the additional heat from higher voltage in my PC room it's not even a question for me to keep the voltage low for comfort of temperature and comfort piece of mind for the silicon longevity and stability.VID can be ignored if the Vcore is between the correct margin, VID can have very high spikes even on idle and mean nothing, vid is the voltage identificator requested by the CPU to the motherboard, but not necessarily what the CPU is receiving, before that is applied vdroop and LLC and the CPU receive the applied voltage. and the Vcore at 1.392 without any manual adjustment isn't bad for those cpus.
The king is dead... long live the king!“We are pleased to inform you that your warranty claim has been approved for the following product(s) under RMA# Xxxxxxx. OPN 100-100001084WOF, Serial Number Xxxxxxx Please note this RMA is only valid for the product(s) with the OPN and Serial Number mentioned above. Unauthorized / unapproved items that are not listed above will be discarded or returned at your own cost.”
(Just moments ago)
https://videocardz.com/newz/tech-ci...steel-legend-wifi-latest-bios-does-not-fix-itThe king is dead... long live the king!
Well, hopefully it's just a bad batch of CPU's, and you get a good one. If it happens again, maybe try out a new motherboard, lol.
9800x3d on asus tuf gaming x670e plus wi-fiWell, hopefully it's just a bad batch of CPU's, and you get a good one. If it happens again, maybe try out a new motherboard, lol.
I think it's fine, solid VRM's. Was validated since BIOS 2613. It's just difficult to know what caused the issue without a lot of data. Not just from you, but from AMD, board manufacturers, other people, and custom computing companies like Puget Systems. If it's not a CPU batch problem (AMD), or a motherboard BIOS problem, it's typically BIOS voltage settings or user error. High voltages (VCore or SoC), poor cooling, or maybe the CPU cooler was too tight on one side. Who knows.9800x3d on asus tuf gaming x670e plus wi-fi
is this weak? the 9800x3d is on the validated list
https://www.asus.com/us/motherboard...qvl_cpu?model2Name=TUF-GAMING-X670E-PLUS-WIFI
I believe even one of AMD's guys said something about 1.20v or something being safe but anything over causes degradation. Its why I use that guide to control my volts to 1.20v while keeping my temps at 80C max.This is why I generally always keep an eye on the voltages the for the mb/CPU. Very interested what they were previously. Both Intel and AMD run voltages higher than they should be shortening the CPUs lifespan. Try to always run hwinfo so you can see the average and max spikes after gaming sessions.
Typically 1.1V's is fine. If you're overclocking RAM, sometimes you'll need it higher. But scaling the SoC voltage down and testing your stability is the best practice.I believe even one of AMD's guys said something about 1.20v or something being safe but anything over causes degradation. Its why I use that guide to control my volts to 1.20v while keeping my temps at 80C max.
Found it...
https://www.reddit.com/r/ryzen/comments/1gq1yu9/universal_guide_to_configuring_all_ryzen_9000/
I'm talking CPU volts, not SoC.Typically 1.1V's is fine. If you're overclocking RAM, sometimes you'll need it higher. But scaling the SoC voltage down and testing your stability is the best practice.
Oh.I'm talking CPU volts, not SoC.
9800X3D with PBO are fine in ITX mobos with 8 phase VRM and smaller heatsinks.9800x3d on asus tuf gaming x670e plus wi-fi
i don’t even do PBO, run stock OOTB9800X3D with PBO are fine in ITX mobos with 8 phase VRM and smaller heatsinks.
Sure. Point is, a 14 phase VRM is overkill. For all current AM5 CPUs, actually.i don’t even do PBO, run stock OOTB
what’s the deal with all these 16 and now 18+ phase boards being recommended anymore?Sure. Point is, a 14 phase VRM is overkill. For all current AM5 CPUs, actually.
“The 24+2+2 power phase design saw a peak of 62°C, but after half an hour dealing with our Ryzen 9 9950X at full load, only one thermal probe topped 60°C with the rest sitting in the mid to high 50s. A decent result thanks to a large dual heatpipe upper heatsink array and rear cooling too.“what’s the deal with all these 16 and now 18+ phase boards being recommended anymore?
https://wccftech.com/best/best-motherboards-for-amd-ryzen-7-9850x3d/
after rebooting twice with that Beta BIOS above i’m now within 2 fps of my best 9800X3D score on this 9700X:
Just FYI CPU power connectors are wired together. It's just to spread the load across more contact points, it won't hurt to run more cables and I would say you may as well but if the power supply only has 1 then it's not an issue.I mean, sure, just use one CPU power cable when there's two CPU power plugs. I just take the side of caution since I don't own any design schematics on how the power delivery works for the motherboard. Maybe there's load balancing, maybe there's more stability, maybe maybe maybe...
also ASUS just released a Beta bios and mentioning my generation of CPUs,
Version 3841
Addresses potential boot failures and stability issues observed on certain Ryzen 9000 configurations
