- Dec 2, 2004
Sapphire Radeon HD 7970.
Working on overclocking now and will compare my old 570 SLI medium-OC 3dmark score (Extreme preset) to it once it's done. Looking really promising so far.
congrats! looking forward to oc results and any gaming comparisons you want to give.
i assume for your first overclock attempt you just cranked it to 1125/1575 with no iterations in between?
How did you increase the voltage? Trixx?
are you using the 7900 Series drivers released yesterday?
Are you going to be running it in eyefinity? If so hold off on buying another reference and get a aftermarket card with 3 dp outputs to avoid getting the tearing issue.
Congrats GT, first me switching to AMD and now you. What is this world coming to![]()
What's the driver you're using? I'm running 11.12 and my sapphire 7970 is hitting 1125 core and 1575 memory without a hitch.
I "recycle" old video cards, you just send those 570s here.
going from nvidia to amd, did you bother with driver sweeper and all that nonsense? or did you just uninstall nvidia drivers and then install the AMD drivers?
Awesome clocks so far. Probably time to put that bad boy on water, and away it goes.![]()
Damn, QA issues on the other card. It started overheating and I'm saying WTF. Pull it out do some trouble shooting and the damn fan plug isn't seated. Do they test these damn things before they send them out?
Both cards are working, but I had to work on them to make it so. First card had a fan that wasn't attached to the HS. The second card the fans didn't run until I seated the power plug for them. Neither of those cards should have made it past QA like that.
Both cards are running nicely at 1125 core and 1480 mem at default voltage.
i've got to say, i'm not very impressed with this XFX Black DD cooler. at 1125/1575 the card idles at 60 C and i got it up to 79 C at 80% fan while playing BF3. might have to pop it out and take a closer look at the HSF.
GT,
Do you notice voltage not going up or down when adjusting with trixx but GPU-Z does not show the change for voltage?
Ok I raised mine to 1200 core and 6000 memory, i was getting some artifacts so i wanted to bump up core voltage by .01 from the default of 1.17 to 1.18 or 1.19 perhaps, after i apply the changes in trixx,
GPU-Z would show the correct clocks of 1200 and 6000 memory but still shows default voltage of 1.17
