Xer...is there any chance that perhaps your powersupply caused your video to go bad? If it was me, I would replace that PSU asap.
I don't trust OCZ.
Just a siggestion.
~FID
May I ask why you dont trust OCZ? I bought some RAM from them for this computer and initially got a bad kit... but I immediately got to their tech support, and they offered the best support I've experienced through a hardware company. I RMAed the kit, they sent me a brand new one, and it was perfect.
Sounds like it could also be a power supply problem.
Has to be one of the two. Like if the PSU is crapping out, because it cannot properly power the Video card anymore. It seems odd to me that your PSU shuts off, I would think even if the card was bad you would get some error codes or beeping. (Not necessarily true though).
What was causing the PSU to shut off was a short somewhere. I've seen it happen before. Hell, if you want to try it, its real easy with a set of cathodes... just take the metal parts of the switch that turns them on and off, and touch them to the case. The PSU shuts off, but theres still power there.
The video card was causing a short when it was plugged into the PCI-e slot, thats the only conclusion I can make based off of the behavior I've seen. I've had a PSU die a slow death on me on another computer, and the symptoms were completely different (lock ups, blue screens, strange noises coming from the PSU, hard drives powering down while the computer was on, etc.)
It was only when I removed the video card (nothing in the PCI-e slot) the computer was able to boot and get to POST, and then it would give me the beeps for missing/bad video card.
But since you were having issues with the video card (probably loose heatsink) I would also say that is most likely the problem.
Now that you mention that, the heatsink did seem a little looser than I remember it being when I installed it. Who knows what happened.
When your video card said the core was too hot, did you check the temperature? My 7800GT runs hotter than my CPU.
I realize that a GPU's threshold for temperatures is far greater than that of a CPU, but when I say "was running a little hot" I'm talking 115 degrees celcius.
Don't have an ancient PCI video card to try?
Well, right now I'm running the same computer with an 8800GTS 640mb. All systems seem operational, the temps look a lot better than my 7800gtx actually, and as far as I can tell everything is powered efficiently.
