My 7600GT AGP
GonzoP
Just arrived in the past hour. Its the same size as my Ti 4200. I just plopped in it and did the proper driver cleaning as recommended in the sticky atop the Video Cards Forum Page. Initial impressions are very positive :D
First thing I did was not run anything from 3DMark but instead fire up some Far Cry. Whereas with my Ti 4200 I ran 1024x768 and generally average in the 20-30fps range I suppose [it would]ary hugely though as I could get 60+ when going down corridors :rolleyes:] on medium detail levels; I now set to 1280x1024 on high and was probably averaging close to double the fps in some modes.
But since almost everyone and their dog will ask for the 3DMark stuff here it is. This is with the lastest Forceware 91.47 and no changes to the detail levels, no LOD bias, as stock as stock gets. Even the speeds were stock i.e.560/700[1400]:
03: 12207
05: 5897
I did hit the detect optimal button and it gave me 604/797[1594] but I didn't enable those. I'll probably put some AS on the core before I OC it and maybe even volt mod it ;) :D . I really don't want to go back to the days where I'm chasing various drivers down to max out my 3DMark score. I'd guess with a proper OC those scores would probably end up in the 03=14K and 05=6500 neighborhood but who really cares.
Next thing I'm doing is trying out all the demos I've got FEAR, COD2, Prey and Q4. This should be quite a treat from my Ti 4200.
I cannot advise agp users highly enough on this baby if you can order one while they're in stock. It doesn't appear to be much of a leap from a 6800Ultra but it is slightly.
Updates to follow.
kirbyrj said:
What do they run price wise (out of curiosity)?
About $175. I know pci-e users can get 7900GS's are just a tad more than that or x850xt's for quite a bit less but at least I'm back in the game.
For agp its a great value. Nearly the performance of the 7800GS for about $100 less.
Yeah, from what I've seen, the X850XT and the 7600GT are about equal depending on what you're doing. The X850XT is hard to find and expensive in AGP though. $175 seems about right.
Glad to see you're liking your new card. :)
Love mine too.
Just got Company Of Heroes and started the tutorial as I am unfamialiar with RTS games.
COH has a graphics performance test in the options.
I'm running it 12x10 with my Leadtek 76GT, 2.8c, 1.5 gigs of Mushkin Redline 430 Antec TP etc.
Got 5647 05 mark score with 91.47's
OK I auto detected at 606/800[1600] and re-run 03 and 05
03: 13165
05: 6489
06: 3235 = SM2.0=1457, HDR/SM3.0=1339, CPU=938
BTW cpu is a 2.62Ghz AXP
i hit 3100 on 06 and 5500s in 05
didn't know that XP processors did better than northwoods...
i'm pretty happy with the card though, lets me run higher quality on bf2... just isn't a huge jump over an ATI x800 gto unlocked.
Yeah my AXP at 2.6Ghz is about the equal of your 3.3Ghz Northwood. I almost jumped on a x850pro or x800xl a month ago but I waited too long and they were out. The 7600GT seems to be about 10-20% faster than the x800's; so yes it isn't a giant leap from where you were, but still pretty good for agp
Interesting how your 05 score is 1000 points higher but only 100 points higher on the 06. I wonder how that came out. My card auto detected to like 600 and 791. You planning on volt modding it?
An AXP at 2.6Ghz is flying. Must be a mobile :cool: .
I'd like to but I'm not sure the agp cards are set up the way the pci-e's are. I googled the 7600gt volt mod and of course vr-zone has a nice little article on it but looking at the backside my card it doesn't look the same. If I can I will if not I guess I'm stuck around the 600/800[1600] neighborhood which isn't too bad. The volt would probably only take me to our 650/850[1700] anyway.
Yeah I could not tell you why there's so much difference in our scores from 05 to 03. BTW what did you score in 03? I even ran 01 but failed to crack 20K :confused: I thought for sure this card would be 22-24K but I guess not. Again I'm not a 3DMark disciple anyway but they are such universal benches that I guess we gotta use them
Yeah its a mobile. And yes with this baby [at 2.62Ghz to be precise] I'd guess my cpu is the rough equal of a A64 3500+ at stock. That's not high end to be sure but I have just enough ponies to avoid upgrading the whole system. Now with the 7600GT I'm probably going to ride her out for another year and make a massive quad core system upgrade in a year
Ya I'm not exactly a 3dmark disciple either. When I went from a 6800 GS to a x800 gto (both unlocked, the 05 score dropped about 500 points from 5400 to 4900... But I was running BF2 a LOT smoother and a half life benchmark jumped up to 80s.
With the 7600GT, my same half life benchmark went down to about 76 fps, but that's probably due to ATI being stronger in half-life type games. But I can play BF2 and have the FPS stay higher at medium settings than it does on my old card at low settings. I still turn off dynamic lighting and shadows for viewability though.
3d03 score 11,500
I dug up my old 6800 GS scores and I was actually able to get 11,800 on that when unlocked and overclocked.
Tzzird said:
3d03 score 11,500
Probably the 16 pixel pipelines helps out there.
