I have a 2 gig 6970 with no bios switch etc.. currently powering 1 HP2710m which is a 27inch 1080p TN 60Hz LCD, and 2 21 inch 60Hz Dell IPS'es.
What I really want is a 30inch IPS or TN ( this size would be IPS more than likely) 120hz monitor, but I also love the massive resolution that non 120hz monitors bring to the table.
Anyway that is not even the point.
Question 1
Can this 6970 power 3 27" 1440p Korean LED monitors? A regular usage scenario would be the two side monitors being on desktop and the center one playing Stracraft 2 at low settings but native resolution.
Question 2
Can this thing manage if I can get the center monitor to be at 120Hz? I am not sure if this is even possible but was thinking keeping the flanking 27's at 1440p 60Hz and overclocking the center to 120Hz if possible. I would also not mind waiting for the right monitor to come out for that.
Question 3
Since I also encode video at 1080/720p and stream my games on twitch TV, I put a good amount of stress on my video card and CPU. The option I asked on question 2 seems hard to achieve anyways, so how would a another 2 gig 6970 in Crossfire fare in this situation. Would it help the 3 1440p standard refresh rate monitor situation? Would it help the 2 1440p 60 Hz 1 1440p 120hz situation? or both?
To be real honest I am pretty undereducated on these newer LG IPS panels and I don't even know which ones are overclokable or even how to do it, but doing some preliminary ground work right now. I want to get this setup going within 2-3 months at the latest.
Question 1
Question 2
Question 3
