SeaFoam
- Oct 13, 2004
I don't know how many of you have been following the development of this mod but it will be coming out on December 26th!!
Those of you who don't know what it is - it is a total conversion mod for Crysis that is centered around the Battletech universe. I for one miss the old days of playing NetMech and am pretty excited for the release!
Edit: With our latest release 0.4.0 we also support Crysis Wars. After 0.5.0 we will only support Wars.
http://www.mechlivinglegends.net/
http://www.youtube.com/watch?v=lNFeE8mIlxQ&fmt=22
THIS IS EPIC
Before installing this new version of Mechwarrior: Living Legends please first delete your entire mwll directory in your Mods folder. Please ensure to keep a backup of your custom maps prior to deleting it or you will lose those or any work you have done on them.
Installing the latest version of MWLL is as easy as downloading our latest installation package. It will include all required files to run the update procedure. You will be asked to run the “Auto Update” right after the setup finishes to install. Please confirm the checkbox is checked and click Finish to start the update procedure.
The process can take quiet a while to complete. The total download size for the entire update is 2.5 GB. You will be offered to retain a copy of the update package (ZIP) and the Torrent file for further distribution through your favorite Torrent client.
Server Installation
If you are already running a dedicated server of MWLL 0.4.9 you will need to delete the entire MWLL folder from the server. Be sure to keep a copy of all custom maps you wish to use with MWLL 0.5.0! Then upload the entire MWLL 0.5.0 content in the ZIP to your server or ask Customer Support to download the ZIP for you and install the content into the ‘Mods/mwll’ directory. Future updates are incremental and can be added to the existing 0.5.0 installation.
dropship deployed, after downloading the MWLL download client(bittorrent client), make sure to set the upload limit to 75-80% of your connections actual upload capacity, it defaults to 0 (100%)
Version 0.5.0
New Features
- new game mode : Solaris Arena
- new game mode : Last Man Standing
- SA/LMS custom scoring & awards system
- Crysis Wars HUD system implemented
- map auto-downloader system enabled with custom z-lib extractor library
- new award indicators on HUD for award types
- chainfire now supported for all weapon groups individually
- Cbill rewards will now be shown below the cbill display with a icon indicating the reason for the reward
- New League Mode cvar sv_leaguemode_ams to disable AMS turrets
- Console command to dump the MWLL asset and weapon prices ( dumpMwllPrices )
- TC maps can be used for TSA and TOS for scrims
- add cvar hud_spec_minimumMode, hiding the "Spectating" message and
camera lense flash effect in spectator modes for a cleaner image when set to 1
- add 3 new actionsmaps for spectator z-axis movement, specmoveup (bound to 'r'), specmovedown (bound to 'f'),
- specmovez (bound to joystick_z) without current Actionmapper support
New Content
- new variants for Mechs and vehicles
- new Map : TC_Sandblasted
- new Map : SA_Glory
- new Map : SA_HelsGate
- new Map : SA_Jungle
- Duncan Fisher Solaris Arena Announcer audio
- single bay 'Mech hangar prefab
- SA stadium model & crowd texture
- SA camtower model
- SA promotional posters
- SA clan recruitment posters
- replaced multiple particle effects (better visual and performance)
Balancing
- lowered per-missile damage for ATMs
- Pulse Lasers now have different ranges based on Clan/IS version
- increased Clan Pulse Laser C-Bill costs, reduced cost of IS version
- AC10/UAC10 now have faster projectile speed
- AC10/UAC10 primary and secondary damage improved
- lowered tonnage for Clan Medium and Large Heavy Lasers
- LBX2/5 (for both Clan and IS) now refire faster and have DPS more inline with series set forth by LBX10/20
- new Uziel "D" and "E" variants
- corrected Sparrowhawk variants
- laser weapons now make audible impact sounds
- screen shake from SRM/SSRM/ATM reduced
- aerospace must land to rearm by default (can be overriden by League Mode cvar)
- aerospace rearm at APCs is disabled (can be overriden by League Mode cvar)
- hitboxes improved for all ground vehicles
- hitboxes improved for Mk2, Madcat
- BA TAG range increased to 550m
- Removed UAC "double jeopardy" cooldown penalty
- Sparrowhawk flight parameters adjusted so it's not as "clunky", but still more manouverable then the Sulla
Optimisation
- heavily optimised TC_DeathValley map to reduce drawcalls and texture memory usage
- bulletimpacts system corrected
- class based sound channel calling system for vehicles
- various Oneshot and MaxChannels issues resolved with sound palette
- tracked vehicle handling improved globally, less slip on inclined surfaces
Bug Fixes
- Fixed streak srms getting stuck in mid air
- turret pitch locking for tracked vehicles when going over rapidly varying terrain resolved
- coolant refill bug resolved
- Aecm fixed
- fixed ammo quick buy behaving incorrectly sometimes
- fixed a crash caused by the respawn timer getting loaded and unloaded on every spawn
- Disabled firegroup input while cbill sharing menu is open if there are key conflicts
- Fixed partial ammo reload costing price of full ton
- Fixed stuck buy zones from APC
- Fixed not being able to buy additional ammo for Harasser E if ammo was depleted
- Fixed corrupted display of coordinates specifier in the map display for
non-english versions of Crysis Wars
- Fixed MRMs 10 and 20 so that they don't have missiles flying off at a stupid angle
- Fixed SSRMs and RACs to not have recoil on non-mechs
- Tweaked PPCs and RACs so that their visual effects should be more accurate to their damaging effects
Other changes
- support for standard Crysis has been removed
- more robust cheat protection system implemented for both client and server
- extraneous start menu options have been removed for greater clarity
- menu CONFIG option now invokes included Actionmapper utility
Actionmapper
- new look and feel, icons for key panel, short descriptions for each action when selected
- moved aero/vtol invert actions close to the actions they belong to
- fix provided for bug where you had to click twice on an action to get it to properly update the key selection UI panels
- added code to preserve autoexec.cfg comments and formatting when writing out
- corrected XI fire action to be onPress instead of onRelease in the default actionmaps
- fixed issue where infinite loop of popups would occur when there's only one profile with no actionmaps.xml file present
Installer
- more verbose pre-installation instructions provided
- installer support for standard Crysis has been removed
Auto Updater
- Fixed download size terminology (thanks to WhiteZero for reporting)
- Updates for the Auto Updater, Beta Launcher or Crash Reporter now called 'MWLL Tools'
- Fixed a bug that caused updates for the Auto Updater not to be installed before any other MWLL updates
- Detect if Beta Launcher is running fixing various crashes related to this
- When the Auto Updater fails to install a file, it will prompt the user with a Retry-Cancel dialog instead of terminating the update
- A new 'Settings' button was added to the update window, clicking on it will pause the update and show the settings dialog.
- Added options to limit the upload and download speed (thanks to ~SJ~ Darthbob for the idea)
- Settings are now global and persistent across updates
- Fixed a crash when multiple instances of the application was attempted to be started
- A 'Retry' option was added to the error dialog when the Auto Updater has failed to check for updates
- Improved the update selection logics to prefer smaller-scale updates
- Fixed a serious bug in the update download and post-installation logics
- All log files and data files are now stored in My Games\Crysis Wars\MWLL\Launcher
Beta Launcher
- Now will automatically exit in most cases when the Auto Updater is beginning to download an update.
- Fixed a bug in the server level rotation generator that caused Test of Strength game mode not to be working properly
Known Issues
- Thor footsteps do not play
- if a lock-on missile system in a LT/RT is destroyed while the system is acquiring a lock the lock-on tone will play continuously
- repairs are not halted when damage is taken, will be addressed in 0.5.1
- MWLL logo in main menu does not support custom menu skin colour (known issue, will not fix)
