Multitask Computer with Light Corel and Photoshop
junglicious
Hi [H] Team,
I am building my boss a new computer since his is 7 years old and out dated. I was comparing some of the pre-built systems from Dell and Bestbuy and figure I could build one cheaper without doing to much work. Haven't been keeping up with what's out there I put this quick system build together. Mainly for web base programs, basic Corel and Photoshop work. Also be able to handle lots of open programs simultaneously. Any suggestions or tips would be appreciated.
Thanks
Summary from Newegg:
COOLER MASTER Elite 360 RC-360-KKN1-GP Black Steel / Plastic ATX Mini Tower $39.99
BIOSTAR TH67+ LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
$104.99 -$5.00 Instant $99.99
ASUS ENGT430/DI/1GD3(LP) GeForce GT 430 (Fermi) 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Ready Video ...
$59.99
OCZ Fatal1ty 550W Modular Gaming Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
$84.99 -$15.00 Instant $69.99
Intel Core i5-2400 Sandy Bridge 3.1GHz (3.4GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000 ...
$189.99
Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
Model #:CT128M4SSD2
$219.99 -$40.00 Instant $179.99
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) $46.99
Logitech Wireless Combo MK260 920-002950 Black USB RF Wireless Standard Keyboard and Mouse
$29.99 -$4.00 Instant $25.99
ASUS VH202T-P Glossy black 20" 5ms Widescreen LCD Monitor w/ aspect control
Model #:VH202T-P
$149.99 -$50.00 Instant $99.99
Microsoft Windows 7 Professional SP1 64-bit - OEM
$139.99
Subtotal: $952.90
It would help if you answered the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Basic Photoshop/Corel. Web base programs, lots of multitasking.
As low as possible, less than $1,000 for the whole desktop.
California
Open. Would like it to last 5-7 years. Parts are listed in first post.
None
6) Will you be overclocking?
No
Do not have one, but thinking around a 20" monitor.
Soon as I figure out what parts I should get.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
None of those special feature, but USB 3.0 would be nice since that is were things are going.
Will be purchasing one. Win 7 64bit Pro
- PSU wise, I recommend this better quality PSU instead:
$60 - Antec NEO ECO 620C 620W PSU
If you want a modular PSU, I recommend this better quality modular PSU:
$80 - SeaSonic M12II 520 Bronze 520W Modular PSU
- RAM wise, I recommend this slightly cheaper but similar performing RAM instead:
$44 - G.Skill Sniper F3-12800CL9D-8GBSR 2 x 4GB DDR3 1600 RAM
I recommend getting two of the above RAM sets for a total of 16GB.
- I recommend this mobo + OS combo instead since the mobo is slightly better built, comes with an Intel NIC, and is cheaper once you factor in shipping:
$223 - Intel BOXDH67BLB3 Intel H67 mATX Motherboard + Windows 7 Professional 64bit OEM
IMHO, if you are building this for your boss & you wanna have a job afterwards, do NOT buy that POS keyboard/mouse and monitor.
I've had both & they are C R A P....... After 2 days with them I literally wanted to throw them out the friggin window :eek:
There are LOTS of much better products available in those price ranges or just lightly above that your boss will like much better, last ALOT longer and keep you employed too...........
Although I agree with the other poster's recommendations & most of your other choices, I would HIGHLY recommend that you visit a store that sells computer stuff so you can touch, feel & see all the KB's, mice & monitors they have, narrow down your choices there, and then buy them online..... Also if by "multitask" you mean running multiple apps at the same time and/or several app windows open, be sure to go for a widescreen monitor in the 22" -32" range.......they make life SOOOO much better !
good luck with your project ;p
Thanks for the tips. Hahaha. He wouldn't fire me because of those things. I figure this would be better than his Dell keyboard and mouse that is 5+ years old. But definitely noted on a better keyboard, mouse, and monitor.
I am trying to order my stuff from amazon to save the tax and I have prime. There are some stuff that or either higher or I can not find so I choose substitutions. Will these work fine as well?
http://www.amazon.com/Crucial-204-pin-SODIMM-PC3-10600-CT2KIT51264BC1339/dp/B003DZJQQI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1327379979&sr=1-1
http://www.amazon.com/Crucial-204-pin-SODIMM-PC3-10600-CT2KIT51264BC1339/dp/B003DZJQQI/ref=sr_1_11?s=electronics&ie=UTF8&qid=1327380185&sr=1-11
Also the case I orginally picked seems to be sold out at newegg and amazon wants double the price for it. Any suggestions for a comparable case?
Thanks
Thanks, I didn't even notice the ram... maybe I should of looked closer at the image as well.
How good is that 450 true wattage PSU?
It's a good PSU. Otherwise I wouldn't have recommended it
Just order. Hope this turns out good. Total $1058
in no particular order:
2x Kingston Technology HyperX Blu 8GB 1333MHz DDR3 Non-ECC CL9 DIMM (Kit of 2) KHX1333C9D3B1K2/8G
Logitech Wireless Desktop MK320 Keyboard
Crucial 128 GB m4 2.5-Inch Solid State Drive SATA 6Gb/s CT128M4SSD2
XFX P1450SX2B9 450 Watt Core Edition Single Rail Power Supply
Intel Core i5-2400 3.10 GHz 6 MB Cache Socket LGA1155 Processor
Lite-On LightScribe 24X SATA DVD+/-RW Dual Layer Drive IHAS424-98 - Retail (Black)
ASUS GeForce GT 430 (Fermi) 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Ready Video Card, ENGT430/DI/1GD3(LP)
Acer S231HL bid 23-Inch Widescreen Ultra-Slim LED Display - Black
Cooler Master Cooler Master Elite 430 Mid Tower ATX Case with Window (RC-430-KWN1)
Boxed Intel Desktop Board Media Series Micro-ATX Form Factor for Second Generation Intel Core Family Processors BOXDH67BLB3
Windows 7 Professional x64
