Multiple fans per channel?
MaXXimus
If I didnt want to go the nasty route of using Y splitters, how can I connect multiple fans on each channel of my controller?
how is the soldering typically done... would I simply cut the connectors off the fans and then solder them directly to the controller?
MaXXimus, can I ask what controller your using? I have been looking, but most look too cheap. Thanks.
What I do... is snip the connectors to the fans, connect all the fans together, then re-solder on a a few feet of cable, with a 3pin connector on the end.
So, you make your own Y connector...
______​
|3|------------------
\______​
(Sorry for the crappy drawing... the |3| is a 3 pin connector)
Then plug them right into a channel on the controller.
Noob question... fan has the 3 pin connector for plugging into a mobo or onto a fan controller, what the heck is the 4 pin molex connector for that looks like it should be hooked up to a PSU?
Many fans come with both so you can plug it into which ever ONE, you want. If the fan has the third yellow wire on the 3 pin motherboard connector for monitoring fan rpm you will not get that if you use the molex instead. So it just a "universal" power thing, plug it into a motherboard 3 pin connector OR plug it into a spare molex, but not both.
I often cut off the part I do not need with small cutters as close (if not actually inside) to the connector housing as I can get. Make sure you look at how they "daisy chained" the wiring if you do this or you might end up with a fan with no connector at all.
Thanks for the clairfication... and trust me I will be looking over the wiring VERY carefully before cutting anything lol.
