shipwreck-zombies
- Mar 15, 2010
Multimedia work; design and illustration, video editing / motion, 3d, web development. I don't have as much time for gaming as I'd like but that's definitely a factor
Around $1000 but I'm flexible if something is particularly shiny
3) Where do you live?
British Columbia, Canada - I have had great experiences with newegg.ca
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Case, PSU, Motherboard, CPU, RAM, CD/DVD, Maybe mouse and keyboard if something comes highly recommended
HIS 5850, WD Black 1TB
6) Will you be overclocking?
Not seriously, no
I have three 22" 1920x1080
Within the week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No strict demands, though I would like to experiment with Crossfire at some point
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
Windows 7 64bit
I am thinking:
Case: Corsair 800D
PSU: 850HX
Motherboard: GIGABYTE GA-X58A-UD3R
RAM: 8GB G.Skill
I have a hard time discerning between processors, though I imagine i7 is what I'm looking for. I haven't used any fancy heat sinks in the past but I would be stoked to try if one comes recommended.
I rarely use CD/DVD so I guess anything SATA
Thanks for your time
Not seriously, no
Within the week
Windows 7 64bit
I am thinking:
Case: Corsair 800D
PSU: 850HX
RAM: 8GB G.Skill
