The last watercooling setup I built was a 2x120 radiator cooling 1x8800 Ultra and 1xE6300 C2D, so its been a while.
So I am going to watercool my HAF 922 and I plan to use a 2x120 radiator up top, but want to add a single 120 to the rear, but before I get to my question, here is my hardware
Case - HAF922
GPU - GTX580 OC'd to 900mhz
CPU - Phenom P965 X4 Black Edition OCd to 4.1ghz
I am currently cooling with an TT Frio on the CPU which is keeping temps at roughly 30*c idle and 45*c load.
Stock Reference cooler on the GTX580 is yielding 45*c idle (Dual 1080p Monitors) and 65*c load (I use MSI Afterburner to engage fans earlier)
Here are my questions.
1) Is a 2x120 enough to cool this setup in an airconditioned office? My E6300 (which was overclocked from 1.86 to 3.1ghz and my 8800 Ultra were cooled plenty a single 2x120 radiator)
2) If I did decide to add the single 120 to the loop, where should it be in the loop? Before the large radiator, after it, after CPU but before GPU etc?
3) I want to avoid cutting the top of the case, so I am trying to avoid a 3x120.
Ideas and suggestions?
Case - HAF922
