MTFDHAL3T2TDR-1AT1ZABYY
ksingh707
  1. Hello, I am trying to connect my micron MTFDHAL3T2TDR-1AT1ZABYY 3.2TB drive to my windows XP system and my windows 7 system.
  2. None of my windows systems are detecting my my drive but the drive is new. I have 2 other new drives. also not being detected.
  3. I am using LSI card and im using a pci cable to connect. I have used multiple pci cables and its giving me the same issue.
  4. The LSI card is detected, not the drive.
If anyone knows how to connect this drive to windows 7 or windows XP, it would really help. Thanks
That's a u.2 drive. Does your LSI card handle u.2?
Which LSI card do you have?
yes its a u.2. and the lsi card does take the u.2
Does the drive show up in the option ROM of the card when you boot?
If your board has an m.2 slot you can get a m.2 to u.2 adapter. Might be easier.
