Would someone point me to a good link for info on the MSI SLI mobo. Looking for windows Ocing software like the asus sli as well as a list of know issues. Thanks.
Have you looked at the 11 page sticky on this forum that specifically talks about the MSI K8N Neo4 Plat SLI?
The only Windows OCing software I've tried is Clockgen, which works fine.
The only known issues I know of is the overclocking of Winchester core CPUs via BIOS. Not everyone experiences this, but most people do. It overclocks fine with Clockgen, though.
A summary of the OC issues:
Winchester cores don't seem to get more than stock voltage at post, so you're limited to whatever Bios OC you can get at stock voltage. In Windows, you can adjust the voltage and FSB using ClockGen and take it to wherever you want to go.
Personally, I set up a ClockGen config to run when windows loads to OC up to 2.4Ghz (9x267) and boot at 2.0Ghz (10x200). It works fine. Never had a problem with it at all.
ClockGen has a version for the NF4. Download that and you'll be fine. It is pretty self explanatory once you run the program. Very easy to use . Enjoy.
no doubt! i went from stock to just 2.3ghz@1.425v and 230fsb. i know this winnie goes to 2.6 but don't want to push it yet. anyway aquamark3 went from 58k to 61,101. clockgen is nice.
Yes, you adjust the memory voltage in BIOS (or the CoreCenter). I also adjust the memory timings in BIOS. You can theoretically use A64 Tweaker to do that also, but it freezes on me everytime I switch CAS latency in A64 Tweaker (other timings work fine). I run 2.5-3-3-7@267mhz@2.75V. No stability problems at all.
Also in your ClockGen config (if you have it set to run at startup like I do), you have to put your voltage first before you change your HTT or else it might freeze on you. It applies them in the order you put them in the config. I do 1). Voltage; 2). Multiplier; 3). HTT
