SLAPL is a C0. The newer C1 Wolfdales aren't out yet, only Yorkfields. Maybe a cross-flash to Pt 1.6 would make it work, but I don't know if the Pt BIOS accepts a board without eSATAII. (Someone who is brave enough might try.)
I tried it and it doesn´t work (P6N SLI with BIOS v1.6 from Platinum)
What do you mean by "doesn't work"? Kills the board, or just doesn't add 45nm support? (Note to crossflashers: don't forget to update NVRAM and everything to avoid creating a "FrankenBIOStein", best tool is maybe AFUWIN 4.33)I tried it and it doesn´t work (P6N SLI with BIOS v1.6 from Platinum)
This is what MSI told me:
"Thanks for your feedback as well.
According to your information,we can say that your CPU isn't the same type as Core2 Duo (45nm, L2 Cache) Wolfdale E8400 (3GHz, C0, 65W).So it can't work with this mainboard."
Soooooo if my CPU isn't Wolfdale that what the heck is it? ---->
INTEL E8400 <------ ???
INTEL CORE 2 DUO
SLAPL MALAY
3.00GHZ/6M/1333/06
Q744A761
It's not like I'm the only person that can't get it to work.
Try jumping straight to 1700, possibly reducing your multiplier. There is a known FSB hole between 1600 and 1700 on this board. (It's not the only hole however, as there is another one between 1160 and 1333.)Im trying to OC my e6550 on a MSI P6N Platinum to 2.8 with a FSB of 1600. I have got it up to 1550 with stock voltage. If I try 1600 it doesn't boot. Any suggestions?
System Specs
MSI P6N Platinum
Core 2 Duo e6550
CORSAIR XMS2 2GB DDR2 800 6400 @ 2.1v 4-4-4-12
Unfortunately there is no known method of doing that, except maybe booting @ 1550 with DDR @ 775, then clockgening up to 1600/800. That way, one can avoid the FSB hole. Or, you can OC your RAM to 850, loosening timings as needed. You might try just upping the CPU & NB volts, but if you are hitting the FSB hole (it is known to exist on the FI version, not sure about Platinum), then no volts will help you. You might even run your CPU @ 2 volts with dry ice cooling, it won't boot even then. (Quick test to see if it's the FSB hole: try booting @ 1700. If it works, even if it crashes after 1 min prime, then it is likely the hole.)I would really like to set the FSB @ 1600 because that would give me a 1:1 ratio. Is there some voltages I have to mess with? Do I have to lower my ram timings? Like I said I can get it up to 1550 on stock voltages with memory timings @ 4-4-4-12 just fine but that gives me a 15:16 ratio... but @ 1600 it fails to boot. I also tried 1575 same result, no boot. I've looked at alot of forums and can't find someone with this board and my CPU so I can just copy setting.
EDIT: Also, what BIOS are you using?
Ok , anyone have any/better luck "yet" on either board with e8400/e3110's working with the newer bios's .
Gonna try my e3110 today on my FI with bios 2.5 . I'll report back .....
*UPDATE*
No go with my 3110/SLI-FI and bios 1.5 . Tried multiple times just to be sure and nothing from the 3110 cpu itself , only power to the system (fans , etc) .
I even swapped out my e6420 and q6600 a few times in between (they booted fine) then reinstalled the e3110 and again nothing .
Well , I hate to say it "again" , but MSI and thier bios Wolfdale update is full of s*** !!! Looks like the last MSI board for me , since they cant get an updated bios correct and all the other competator brands can .
I just tried the e8400 with P6N SLI... It works!!! You just have to flash the bios to the one from this board --> EVGA NVIDIA nForce 790i Ultra SLI DDR3.
Here's the link for the bios: EVGA BIOS
**EDIT**
April Fools ha ha ha
Whoever is still trying to get the wolfdale to work with the P6N SLI FI, here is a good thread:
http://forum.msi.com.tw/index.php?topic=107946.msg863412
Although there is no solution yet, they sometimes post beta BIOS to try out.
MSI tends to mark CPUs "supported" if they can be made to work by overvolting the northbridge. This has happened for quite a few boards during the transition to 1333MHz. Possibly the same thing is true this time. (Just the opposite of what ASRock does: only those CPUs are listed on their CPU Support page, that work out of the box with a BIOS update AND are considered "working" by the maker of the CPU, that is, Intel or AMD. See 775Dual-VSTA for example, works fine with quad-cores, but it doesn't meet Intel's requirements, and it is considered an overclock, so it's not "supported".)
Also, those who got it to work have swapped it in place of an overclocked CPU. For example, one guy in the other thread had an E4300 @ 3.2 GHz in the board before switching to a Wolfdale. Likely he overvolted the board a bit for that overclock, and he might have forgot to reset his volts before swapping CPUs.
A trick which might get the board working with Wolfdales: While still on your old CPU, bump your N/B voltage to 1.35V, add a bit to your Vcore, set FSB VTT to 2%, and set S/B to 1.55V (it might seem to go right to 1.60 from 1.50, but go up to 1.70, then go up one notch, and voilá, it jumps to 1.55 - a bug in the BIOS). Set clocks to Auto, with no overclock. Disable EIST and C1E. Now insert your new CPU, and try to boot. This *might* help. It has been reported that some boards drastically undervolt 45nm CPUs, and the same hack worked on this exact board when it had problems with 1333MHz FSB Conroes. Also, if you have an FI, try the Platinum BIOS, combined with the voltage bumps. I tend to get higher overclocks with it at the same voltages, so it might help in case of an undervolting issue.
It's none of my business, but you got a quad-core running 3.6 GHz on a 650i motherboard.
What the heck do you need a wolfdale for,anyway?
You know you love this motherboard so don't hate on it.
So does the 8400 processor have problems with all of the nvidia 650i boards or just the MSI? Is this likely to be fixed with a future bios update? I checked the MSI forums and they did not have anymore info than we have here.
yep I flashed it with the platinum bios!!! I figured what the heck, i would give it a try, it was either that or I was gonna order a new motherboard. Either way I wouldnt be using this board anymore if it didnt work.
here are the settings that I changed while the 6600 was in.
Northbridge: 1.35
vcore: .125
set fsb vtt to 4% 2% didnt work
set southbridge to 1.55
disabled all of the speedspectrum stuff
disabled EIST and C1E
and I set the clock to auto
and whatever the hidden setting was under cpu when you hit F4 to disabled and the one above it to disabled.
AND yes if you flash with the platinum 1.6 bios it is at your own risk I may have just gotten LUCKY!!
That depends entirely on the manufacturer and thier own bios updates . I know other 650i (and 680i) boards do work with these chips ,such as Evga .
Who knows if/when MSI will do another bios update, considering they say the current bios for both Plat/FI works for these chips . The only responce we get from MSI at the MSI forums about the bios not working , is to contact them directly for more tech support ; which may mean that they could have another beta bios in the works (but thats only spectulation on my part) .
If someone tries this and gets it to work, please post BIOS settings.
Also, let's say I'll get this to work, what if I have to reset BIOS with the e8400 in. To do that I I would need to swap to another CPU, change BIOS settings, put e8400 in? Just thinking out loud.
