You do not need to use any extra driver floppies or otherwise during the installation of Windows so long as you are not using your drives in a RAID array.
Once you've installed Windows be sure and install the latest 650i/680i platform drivers from www.nvidia.com.
When i set my cpu/ram to linked at 1610fsb my ram only reads 377.3mhz in CPUZ, do I need to do something different??
Ok, thanks. Dumb question....Do i still install the drivers that're on the cd with the mobo, or are these replacing those? Like I said, i havent done this in a while...
They would be replacing the ones on the CD (MSI gets them from nVidia).
I'm currently running orthos on my setup @ 3219 mhz with the following settings
cpuv-+.100
NB-1.4
SB-1.5(default)
fsb-1610
memory 1.9
fsb/mem-linked(cpuz only reading 377.3)
So far stable for 48min. 25sec, max temps hit 60c but usually sits around 57-58c. Tried 1640FSB but windows would not boot. My question is how log should I run orthos to consider it stable
blue falcon, why do you have your zalman facing up? it is my impression that you would want the fan facing out the back since i can see the exhaust fan on the back...i'm assuming you have a fan exhaust on top as well?
The one's on the MSI website look to be later versions...should I use those instead or stick with the ones on Nvidia's site? Also, do I use the Realtek High Definition Audio Driver thats on there as well? Nothing off the CD at all then?
Alright, 2hrs 41mins later and still stable on current overclock. This is the best Ive gotten out of this FI board.
So is there any BIOS option to set a 1066 strap for an 800MHz bus CPU like the E4300 and E4400?
Either way is fine.. the ones on the CD are the oldest... the ones on MSI's site are generally updated after the ones on nVidia's site... so for comfort factor, you could just use whatever's on MSI's site (including the Realtek audio drivers).
blue falcon, why do you have your zalman facing up? it is my impression that you would want the fan facing out the back since i can see the exhaust fan on the back...i'm assuming you have a fan exhaust on top as well? i understand the logic having hot air go up, but i would think you'd want the extra air pushing over the mosfet heatsink in the rear
Not to butt in, but if I'm not mistaken that's an Antec 900 case, which means he's got the Zalman blowing directly out the massive 200mm top fan those wind tunnels come equipped with .
whoops, was posting while you were posting... that's a good trick, i'll try that with my p180b, thanks BF
so since my AC freezer is pointed towards the rear, could i change the top fan to intake and basically do the same thing?
also a concern is if i have the front fan intake and the back fan intake and only one exhaust that's going to create positive pressure instead of negative pressure in the case, causing heat to circulate instead of exit the case... but i guess if it's tested method i'll try it.
I'm getting bored waiting for my RMA to get turned around so I'll be joining the traitor camp (for a little while anyways) while I play with a P5B Deluxe until my P6N Platinum gets back . Just curious to see how they compare with the same hardware. I should have the board up and running tomorrow.
Still trying to figure out what happened to my Platinum board. Was great until plugging in the extra drive, but then again earlier on it was funky with that drive attached. Tried it in my GF's system and the HD is fine. Weird. Ordered another SATA drive, so will see how that goes.
Stable is relative . I've seen reports where some setup was stable for 3 hours, but not 6 hours or stable for 6 hours, but not 8 hours, etc. You should have some basic feeling for how stable it is after a few hours... if it looks good then continue tweeking or use those settings. If you later find that some game is crashing (or whatever) then you need to go back and do some longer stability testing to determine just how stable it really is at those settings.
Just got an MSI P6N SLI-FI today and started building a new rig from scratch.
Problem is, my hard drives won't get here until Monday. That didn't bother me, though, so I put together what I could, just to make sure everything fits.
I plug it in, give it juice (the orange light on the mobo goes on), flip the switch, and it powers on... but only for a few seconds. Then it turns itself off.
I know I'm being a little jumpy, but could the mobo detect there are no bootable drives (not even a dvd-rom is hooked up right now) and shut itself off? I'm used to a DOS error message, not the mobo shutting down.
Also: no monitor connected to the video card, but I wouldn't expect to see anything that quickly anyway.
I have to assume I've done something wrong: how do I diagnose it?
Thanks,
Dan
I wouldn't worry too much until you get everything installed, but in the meantime...
Did you screw the motherboard directly to the case? Or is it screwed to little 'stand-offs' which are screwed to the case? It should be mounted to 9 stand-offs, that hold the board up above the metal case plate.
Read a new review of the P6N Platinum today on neoseeker http://www.neoseeker.com/Articles/Hardware/Reviews/msi_p6n_sli_platinum/ He isn't very kind to the board but it was an informative review. I found two things interesting: 1.He used standoffs on the back plate of the cpu cooler to avoid contact with that pesky capacitor 2.The heat pipes use a thermal gum instead of paste, he took them off and applied Arctic Silver 5 instead. Live and learn
edge, thanks for the pictures, i like the "SE" enhancements you did with the dremel, i'm thinking about doing the same.
It's a trick with the Antec P180 and Nine Hundred cases. You reverse the rear fan so that it sucks air in from the back of the case, and then orient your Zalman so it's blowing up towards the top fan. This creates sort of a 'fresh air loop' and will drop your temps significantly.
There is a thread about this somewhere in the cases and cooling or overclocking forums.
Blue Falcon, I may have to try this, my temps are good, but I have my 9700LED fan facing the front, and i get 24-25C idle temps with 3.3ghz on my e6600 (volts 1.45). How do you think this would effect NB cooling? also what speed for the fans?
Blokhead said:PS i've noticed a trend with the newer e6600's only being stable around 3.3, which is what I found with mine. I booted into 3.4, 3.5, 3.6, 3.7 Ghz, but never orthos stable, even with .25V on the CPU. Oh well. Good luck ocing .
cpuv-+.100
NB-1.4
SB-1.5(default)
fsb-1610
memory 1.9
I've found 'linked' mode to be kinda wonky... I usually just use Manual mode and set the memory bus speed where I want it (even if all the other memory timings and such are on auto).
Spanki,
I'm actually having an issue that when I set the Memory to MANUAL at a 1520 fsb (380) for ex. it runs the memory at 760 (as if it were linked.)
[MSI tech support had me flash to the 1.31 bios, but that didn't seem to fix it. And I had tried 1.1, 1.22b also]
If I put the Memory up higher than 800, like to 829, MANUAL (FSB 1520), it will run it at 829, though.
I tried dropping back down to one of the lower settings on the OC (1500 FSB/ 375) and the memory set at 800 MANUAL, and lo' and behold, the memory stays as set in Manual- at 800.
First of all great thread! I started overclocking my P6N SLI-FI paired with a E6600. I need this PC to last so I am not going to push it too far initially. I want to get it running around 3.0 - 3.2ghz stable with low temps. I purchaed a cooler master NB heatsink and fan that was suggested in this thread. I am very glad I did. Just to get it to post at 312mhz (1250) fsb I had to up the voltage on the NB to 1.3v. Is there an application that can monitor NB temps? Also I am having a problem with Ntune where the temperature is not being displayed and all of the voltages show up as not recognized. Any thoughts?
Neo
