misterbobby
- Mar 18, 2014
The review cards have the 1178/1279 by default.1178 is under OC mode. You need the gaming app for the extra boost, similar to the G1.
Sigh 1367 is MAX boost which is about right as mine is 1354. Still if you look at the base and boost clocks in GPU Z it will show 1140 and 1228 at out of box settings.The "OC" clocks in the app are what the reviewers are getting out of the box. This is getting so tiresome to explain over and over on multiple forums.Mine is clocked completely different. I've put Precision to default mode, with 100% power limit, and nothing added to core and memory, and according to GPU-Z, card boosts to 1367. What's strange, is that when I turn power limit to 109, GPU-Z also reports 1367 in Uningine Valley. Uninstalling Precision and Riva servers didn't change anything - without OC software, it goes to 1354. When I use MSI Gaming app, the "OC" tab gives me 1404, and Gaming brings it to 1366.
Not that I don't mind the extra oomph, but it's strange to see it never drop to 1267 - and yes, it's standard retail sample.
Why would that be 130%? Guru3d showed 120% and Techpowerup never mentioned their power limit but it would be either 120 like in the other review or 109 like the retail cards have.http://www.techpowerup.com/vgabios/173582/msi-gtx980ti-6144-150622.html
I think this is the Techpowerup Bios with the 130% power limit.
I say I "Think" because it was added the same day the review came out. So I would assume it would still be 130% power limit since they got that special beefed up Bios in the review.
P.S. I wouldn't think it would void the warranty either since its an official MSI bios.
It is 50 mhz and the point is that only review cards got this so its a bit sneaky on MSI's part. But since most people will oc anyway, the main issue is that reviewers got the 120% power limit where retail cards only got 109%. The 109% power limit holds the card back from performing consistently when overclocked. For card that cost me 700 bucks, it is really bothersome.OMG WHERE MA MEGAHURTZ LOLZ!
But seriously, 35-40 MHz differential is meaningless. Either way I am going to be overclocking mine so don't care about the 1140 vs. 1178 differential.
Can someone look through that BIOS and see what it says for the power limit?
Um what? Power limit has been the limitation for me on every Maxwell card. One of the main reasons people mod their BIOS is to have a higher power limit. This MSI card can do 1526 but hits the power limit hard in demanding games or benchmarks. Even at 1421 on stock voltage it hit occasionally hits the 109%.I have yet to see power limit matter in overclocking any of my cards including 670, 780 and 970 series. Maybe this time it is different. Will find out.
Is there anyway to look at that and see if it has 120%?Wow am I an idiot. I do think it is, The bottom of this page even says review sample.
LOL /facepalm
But wizzard never said it was 120%. That was only shown in the guru3d review.I don't see why it wouldn't. Not like wizzard would put a modified bios on there and call it review sample. Would be bad business.
But yea thats a MSI bios too, so flashing it would be even easier from what I remember, been awhile since I flashed my 970.
If wizzard would just reply to me in the forums it could save me the trouble lol. I have asked twice now but no reply.Hmm I guess only way to find out is to flash it. Backup and save your official bios, then flash with that review sample to check it. Then flash back if it doesn't have 120%.
Edit: Just a reminder. Last time MSI release a video card with a really high power limit (780 lightning cough cough) They pulled the bios and set a 109% on all future lightning cards.
So I would almost grab that bios to check, and keep it around. Just my 0.02c
See my signature. I hit tdp limit before I hit power limit. I can run the cards at 1527 at 100% or 1542 at max power limit.Not sure how you never had that be an issue. My 780's had the issue, stock 970's did as well.
I mean it doesn't mean anything if you don't overclock I guess.
This review also showed the 120% that guru3d did. The out of box clocks are the same as the techpowerup review too so it is likely the review card BIOS on techpowerup does have the 120% limit.
http://elchapuzasinformatico.com/2015/06/review-msi-geforce-gtx-980ti-gaming-6g/8/
Techpowerup only got 1507 max boost clock and that review here would have been just under 1500 actual max boost so it seems the 120% is not really helping anyway as I blow that away for max boost. Even guru3d only got max of 1504 and it was throttling down down to 1477 and even 1450 in some games. Makes me wonder if the retail BIOS had some other changes and the 109% seen on retail is giving the same effective power limit as the review cards with 120% got. By that I mean the 109% might be based off a different base TDP number.
Here is what I am thinking:
120% x 250 watt TDP= 300 watts limit for review
109% x 275 watt TDP= 300 watts limit for retail
Ordered one from BHPhoto Then my 780 Ti goes up for sale.
I played around in Tomb Raider on my every day oc and then the highest oc I have used for some benchmarks. This was on 2560x1440 with ultra settings with no tressfx and only FXAA.
1421/7200 127 fps in game and my total wattage at the wall was 406
http://postimg.org/image/6vpldlc0h/
1518/7800 137 fps in game and my total wattage at the wall was 456
http://postimg.org/image/7o8w180gf/
With more voltage and higher power limit this card could easily maintain about 1550 in games as I am hitting over 1530 in parts of games until the power limit is reached. Makes me wonder what the Lightning model can do. lol
It is not going to do any good. Not a single review card can oc theirs to what I am getting and even they were throttling and not able to maintain it. For example, Guru3d was was only getting 1450-1507. See my earlier post as to why this probably is. http://hardforum.com/showpost.php?p=1041710468&postcount=461I'm just curious who is going to flash http://www.techpowerup.com/vgabios/173582/msi-gtx980ti-6144-150622.html first.
Lol if I crank the fan to 80% I can get 1561 if its not a super demanding game pushing it much over 100% power limit. In actual gaming I use vsync so even most demanding games could probably maintain around 1540 or just a little lower since I would rarely go hit even 100% TDP. My everyday OC is a very conservative 1421/7200 at 1.174 though which is WAY better than my reference 980 Ti could maintain even with the fan screaming.While I'm gaming with the Witcher 3, after a while my freq starts to fluxuate a little bit.. even at low overclocks if I tame it down. It'll change 5-10Mhz up or down, I'm at about 102% voltage seems to stay pretty constant...
