- May 18, 1997
MSI K9A2 Platinum - The AMD 790FX chipset is definitely popular with motherboard manufacturers who are all churning out their own boards using the chipset. Today we look at MSIs 790FX the K9A2 Platinum and take it for a little test run.
The MSI K9A2 Platinum is a motherboard that was built specifically for running AMDs Phenom processor and CrossFireX. If that is what you use it for it works well with a Black Edition processor. It can run stable and enjoys some healthy Phenom multiplier overclocking but you need to be aware that you need to put some airflow on the boards passive cooling devices.
