rabiddawgs
- Aug 16, 2004
I just got the above motherboard today in the mail.
i ordered it from cheapguys.com.
first off the box was not the normal platinum box. its just the basic msi green box.
the tag does say plat. but has +54g after it. not sure what that is.
the box wasant sealed, not sure if its supoposed to be or not.
opened it up and all the accessories look right except it didnt have the plat. red rounded cables it just had some flat ones but they were kinda rounded with black mash cable sleeving.
upon further inspection of the mb the antistatic bag had scotch tape keeping it closed. again not sure if msi does this or not. seems odd to me.
i have never used MSI before so not sure.
also it kinda smelled like electrical burnt type of smell.
i looked at the mb standoff holes and it looks like it has been installed before.
also where it shows the model number for the mb inbetween pci slots 1 and 2 it says k8n neo2. between 3 and 4 it says ms-7025ver 1. all the other plat i have seen says k8n neo2 platinum not just k8n neo2. is there another version of this.
another thing im not too happy about is the date code is november 04. since the warr starts when it was made. i have lost almost a year on the warr.
should i call them up an say something about these issues or just use it. i have not opened the bag yet.
