http://www.newegg.com/Product/Product.asp?Item=N82E16813130529
finally out for all you guys that have been waiting for it. any takers?
Godlovesaterrier said:Im really confused with all this stuff,
can it hold an opteron
I dont plan on overclocking so do I need opteron but still need dual core, go x2 maybe
I plan on getting a 7800GTX 512, so whats the deal with the 6150, what does that mean?
going with a 7800gtx, whats the point of having the dvi on board?
Steeeeve said:I have the new MSI Ati xpress200 which is the same as this board but with the Geforce chipset. They are not great OCing boards but they are better then the first 939 released MSI mATX board (which had the Ati chipset as well but the old verison)
Mihai Lacatus said:More here . If. smb. finds more info about oc'ing options please post. Thanks !
Stupid_Newbie said:This could be the best matx board out, if it can hit over 250mhz FSB
My Jetway AGDMS can do that.Stupid_Newbie said:This could be the best matx board out, if it can hit over 250mhz FSB
arabdon1203 said:why would they make the slots like that.
Soymilk said:all i want for christmas is a 6150/430 board that has vcore, vdimm, working htt multi, memory dividers, and can hit 300fsb. is that too much to ask?
If DFI will ever release a good mATX board...RadCliffeX said:ugha, i have always felt the MSI board to be kinda generic or just plain POS boards--Ill wait for DFI before i jump on any mATX boards
Probably that other post where I asked the same thing and never got a response. He picked a good name.Mihai Lacatus said:Source of this info ?
... I haven't seen where it gives more OCing options then this board...FooTemps said:uhhh.... have you seen the stats that MSI have given on this board? It comes with whole new overclocking options packaged with corecell
Manual page 2-17 said:The Mainboard supports four serial ATA connectors SATA1~SATA4. Each supports 1st generation serial ATA data rates of 150MB/s and is fully compliant with Serial ATA 1.0
yeah thats all on page 3-11 as I recall.Mihai Lacatus said:The manual is for the whole series including for those with 410 SB. But here states clearly that is SATA 2 with RAID 0, 1, 0+1, 5. As I see in the manual the BIOS has CPU clock, voltage, HTT clock, PCIE clock, and VDIMM.
