AlphaAtlas
- Mar 3, 2018
While the stable version of MSI Afterburner already supports Nvidia's OC scanner tool, the feature only works on RTX 2000 series cards. However, the developers recently posted a new Afterburner beta that supports automatic overclocking on Pascal (GTX 1000 series) cards. The new version also adds voltage/frequency curve editing for AMD GPUs, as well as support for voltage tweaking on a few RTX 2080 TIs with custom PCBs, among other things. Guru3D notes that 4.6.0 is still in beta, and isn't intended for widespread use in systems where stability is important, but you can grab the latest binaries on Guru3D's download page if you want to give them a shot.
Gents, this is a public beta, but it is just that, an early beta. Considering the binary is spreading fast I decided to move the beta towards a public beta on the download pages so you can securely and safely download it from Guru3D. The new beta holds V/F curve support for AMD cards, OC Scanner for Pascal GPUs, new monitoring GUI enhancements and much, much more.
