I set up this card yesterday. Performance is nice, almost more than I expected, and there seems to be a lot of headroom with the small amount of testing I did so far. Drivers are perfect after simply uninstalling the previous Cats and installing the June 6 betas. But the card is running really hot, even at default settings of 1100MHz core, 1200MHz memory and 1.168V for the core. I came from an XFX dual-fan 6870 which usually sat around the 70s in games while being pretty much inaudible. Ambient temp here is about 24C.
With the 7870's default fan profile, however, it was getting far too noisy in any game I was playing. Looking at Half-Life 2, the game settled around the low 80s, but the fanspeed was staying around 93% and even 99% after it reached 84C. I set up my own profile to deal with this, but with that the card was reaching 90+ C in games.
Using my custom profile, I've tested Metro 2033, where I don't go above 35fps. With the default fan profile the GPU doesn't go above 77C with a fanspeed of 76%. The card settles around the upper 80s with fan speed at a loud 59%, and cracks 90 and fan speed 100% once I get into some action.
Running around dust2 in Counter Strike Source, it takes about a minute for the card to reach 90 C with the same 59% fanspeed. I'm averaging about 130fps (using SSAA) without vsync.
Skyrim and Morrowind settle around the mid 80s with fanspeed between 57-59%, but once I get into combat they both crack 90 as well.
I'm not sure if the case simply isn't providing enough airflow for the card. I've got an 800D which isn't the best at air circulation, but the CPU temps are still reasonable with the 7870 installed. I can't imagine the power use of the 7870 is so much higher than the 6870 that my case would have this much trouble with it.
My results seem a lot more in line with what Techpowerup got than with Guru3d's results, but even Techpowerup got somewhat reasonable temps I'd heard that the Twin Frozr was up there with the other good vendor air coolers; are my results normal?
