MSI 785GTM-E45 mobo info needed
BodyBagz
Yep, I have yet another question regarding the system in my sig..
In the Manual for this mobo, it describes the Overclock FSB Switch...which has 4 settings: Default, Increase 10%, Increase 15% and Increase 20%. Now, I know very little about overclocking...but I am wanting to learn...so, heres my question...
If I select the 10% Increase, what type of advantage will that give as far as an overclock on my 7850 BE(2.8ghz) chip? Will I need to do anything other than adjust this Overclock Switch...this board also came with MSI`s Overclocking Utility Package, as well as AMD`s Overdrive application. I have already enabled the ACC menu in the BIOS, but I dont know exactly what it does...I do know that I can adjust the multiplier on the proc, as well as Vcore by way of either Overclocking utilities already listed...but I dont want to fucker up anything with my little know-how...
Can I get this chip above 3.0ghz without toasting it and it run stable? Anyone have any idea what the max overclock might be on stock cooling? Any info is well appreciated...:D
Anyone have any ideas...advice...or a STFU and GTFO....lol?
STFU and GTFO =P
You have a BE processor so you don't need to necessarily mess with FSB. You can just raise or lower the multiplier.
And ACC in your case isn't needed; ACC is used to unlock cores on AM3 processors.
STFU and GTFO =P
:cool:
Ok...that answers that...overall consensus I have found is this processor isnt unlockable, so there is no point in me messing with anything. I`ll just run it stock for the time being...I did bump it through Overdrive up to 3.4ghz and all seemed well, but I did no stress testing..so who knows..:p
:cool:
3.4Ghz over 2.8 is a nice jump in speed. If it's stable, just run with that.
I think I had my OC number a bit off...seems I cant get above 3.1996 on stock voltages. I just tried again through the MSI Overclocking Center software...bumped the Core Clock to 224mhz and was stable @ 3.1996...bumped to 225 and the system rebooted.
If I can get to 3.1 on stock voltages, wouldnt it seem likely that I could go higher if I adjusted the voltages accordingly? Again, I am somewhat new to overclocking, and basically want to see what this chip/board can do just for shits and giggles since I dont game.
Would I need to adjust voltages Up or Down to get a higher OC? Upgrade HSF as well I am sure since this is basically a stock set-up Product Link/ OEM Cooler
Thanks to any who reply...all help/info is appreciated accordingly...
I'd see if there's a good AMD OC guide (there might be one in the AMD Processors section). Basically, you're going to adjust your voltage up slightly. And you might have to adjust your HTT and memory speeds down slightly (maybe) as your raise your bus speed. But yes, if you can get 3.1Ghz on stock voltage, you should be able to get a little more out of it. You might get more out of your stock voltage if you adjust your memory properly to find out where your board craps out with HTT, RAM, and CPU.
*Bump for a new question*...
Ok, I have this board, and since I just purchased it a few weeks ago, and I happen to like its features, I was contemplating purchasing either a Tri-core proc to unlock to Quad or a bonafide Quad core proc to replace this locked dual core. My question is this...would it make more sense to spend the extra few $$ to buy the guaranteed Quad or save the $$ and buy the Tri and hope it unlocks since I am certain with this boards ACC it will do its portion of the "unlocking"?
My main reason for this is for movie/dvd ripping and encoding purposes...my own movies and those of friends to make them more portable since we are in the military and dont want to have to tote around sacks of DVD`s to watch on downtime.
This dual core does the job well paired with Format Factory or Handbrake, but I would still like to get the time down to under 45-30 minutes for a 700mb H.264 rip...
As always, thanks to any who reply...
get a true quad....if your doing video you will want to make sure that you have more cores :p (a reason im going from my dual to the hexa when it comes out), i currently rip my vids to .iso's, takes about 30-60 min for a movie, but i cant do two at once :p my recomendation anyhow is get a Phenom II X4 955 BE, great chip, will OC really well(as long as you have good cooling), and will run your video conversion quite well.
edit: btw- there is a great OCing guide in the AMD section located here: http://hardforum.com/showthread.php?t=1327003 goes through all the steps
Cool...thanks for the reply.
I was really leaning towards a true quad...I know just enough about overclocking to fry some stuff with little to no trouble at all...:D
I am gonna check out that guide though...would love to see what this dual core can actually achieve for a stable OC...
Buy a chip that someone already tested to unlock. I got mine for essentially the price of a new one, and someone already tested it to run with 4 cores at 1.4V and around 3.6Ghz. If the hex cores were out already, I'd sell you mine.
I was looking at the hex-cores the other day...wondering if I could run one in this board. MSI`s site doesnt list the hex-core chips specifically, but I know some Asus AM2+ boards will accept the 6core chips with a BIOS revision...I am hoping the same thing happens on MSI`s side as well...:cool:
