MSE 2.0 Released
CommanderFrank
Cat Can't Scratch It
Microsoft has just released version 2.0 of its popular Security System. MSE 2.0 had been in Beta for the past 4 months, testing the new network inspection feature and an improved heuristic scanning engine. The price remains the same for home use….free :cool:
MSE 2.0 is available now from the Microsoft Download Center. If you already have MSE installed, it should have automatically updated by now, and yes, it probably required a restart.
nice, any major changes since v1? I dumped v1 for avast when it failed to detect a virus I had.
Hopefully they didn't "improve" so much that it actually is worse now. I love MSE. Don't over-engineer it please!
Maybe it was because I was already running the beta, but no reboot here.
Some colors are different, Thats all I have noticed
You can lower CPU usage during a scan. default is 50%, you can set a time when quarantined files are deleted, it detects network exploits, will notify if windows firewall is disabled and a few other minor things.
It didn't look like I had been updated either, so I went into Programs and Features, pulled up MSE where the highlight showed 2.0xxxx had been installed.
Does the beta get auto updated or do I have to uninstall it and then reinstall the new version?
does this work on XP64 now ?
I can't imagine it ever well. XP64 is not supported by MS. Their official position is that it was a stopgap until they got Vista out. So while they'll continue providing security patches for it until 2014 as all XP, they don't support any new features for it. It is a dead end system, if you need 64-bit go with Vista/7.
Not saying it is right, just saying that is what it is.
MSE is not as useful anymore since it has become "mainstream"
Hackers realize this now, and there has already been 2+ viruses (as mentioned above) that have passed MSE's protection without it knowing. Good luck, and always remember this. It seems all the free AV programs last a while until becoming popular, then everyone abandons it.
No AV is perfect. You can't catch 100% of malware 100% of the time with 0% false positives. The best you can hope for is to catch what's known and update quickly.
MSE has the same scanning as Microsoft's other AV products like Forefront Endpoint Protection. In the studies I have seen it always comes out near the top in detection.
Had MSE earlier and did not catch one virus I had... just ended up wiping and reinstalling. Was going to anyway just gave me a reason. Used it for a bit and enjoyed it. Might toss it back in and check it out.
Been using MSE since it came out. I was using NOD32 before that on my PC and two laptops. MSE has been pretty good thus far in terms of catching things. I've also installed it on all family member's computers since it's got a very simple interface that's perfect for computer novices.
If you want to update to version 2, all you need to do is go to the MSE website (google MSE and it's the first link) and install again. It will detect that you already have MSE installed and upgrade you.
The major change aside from the colour of the interface is the heuristics engine that is now included in the software and integration of firewall functionality.
Just switched to MSE 1.0 after that AVG system killing update. Switched it on about 15 family and friends computers as well.
My personal machine looks like it still has version 1, even after a manual update. I went to http://www.microsoft.com/security_essentials/ in both FF and IE9 and neither say anything about upgrading to version 2. Even the downloaded installer is not showing anything to signify version 2
Opps...
As I was saying did you click the down arrow next to "Help" and select "Check for software updates"? I've done that on three machines and it worked perfectly. The main screen will look about the same but will have a gray background with a white web looking thing on the right instead of a solid blue background.
For those wondering, if you open MSE and click the Help button there is an upgrade option there. Clicking that will update you to the latest supported version for your system. I have been running the 2.0 beta for the entire time and it was a nice improvement over 1.0. I run this not only on my personal systems but a number of small office networks I manage as well (The client machines not the server obviously). I have had quite a bit of success with MSE and it has significantly reduced the amount of weekly maintenance I perform vs previous solutions of; AVG, Avast and Avira.
As for those randomly hating on MSE, I highly doubt most have even really used it. I have hated MS for alot of things over the years, but frankly this thing they did damn well. That and can you name a single free AV solution that doesn't render your PC unusable during a scan? No? I didn't think so. MSE thus far in my experience is the only one that can run a scan in the background and my users never even know it is running. Me not listening to 50 people a day piss and moan because their computer is performing badly is invaluable.
As for the odd virus that gets by it, well on average I see less get by it then the other solutions I mentioned. The few that do are generally through an infected ad that would have bounced through all of them and takes me 5 minutes to clean off the system. I support over 200 machines in numerous locations and I at most end up removing a virus once every other week. Those are averages that I never came close too previously.
As I said, MS has made a lot of stupid mistakes over the years. MSE is not one of them. I refused to run an AV on my personal PC for years because I didn't need it and never got anything. However for its effectiveness and its unnoticeable footprint I do run MSE.
Tried that. It said I was already running the latest version. I was still on 1.0.2xxx. Had to go to the MSE website and "install" it again to get the new version.
For whatever reason, MSE will not update itself, clicking the upgrade option under the help dropdown box, brings up the upgrade dialog, MSE runs a check, and then tells me I am running the latest version. after checking the version number, it is still 1. somthing.
Simple solution for those having issues:
Uninstall whatever you've got, install v2.0. Takes what, 20 seconds? :D
Just saw this behavior on my tm2 but I didn't even have to uninstall the old version. Just installing the new version on top of the old one by downloading and running took care of everything.
Actually, in on-demand tests, out of 20 AVs tested, it came in 15th. It's heurstic proactive test wasn't much better either. If anyone wants the best AV, get avira premium AV. Not only does it have the highest detection rate aside from dual AV engines AVs, it's a thorn in the side of crypter coders because 9 times out of 10, it's the singular antivirus that detects a crypted virus.
This worked for me too. I installed the new version on top of the old one and the installer prompted for the upgrade.
Like others, I was stuck with the old version. MSE kept telling me that I had the latest version.
In what companies test? Because as the OP said, no AV is perfect and almost everyone has a similar story, like how NOD32 claims it hasn't missed any virus in years.
As an example, in AV comparitives, MSE 1.0 is still rated Advance + in detection and performance. http://www.av-comparatives.org/comparativesreviews/detection-test
REALLY!?
I was a lil upset when I found out it was not functional on my Server2k3 install. I hope this works for it now so that I can ditch my Symantec.
I just confirmed with 2k8r2, installed no problem. Whether or not Microsoft will continue to allow it I don't know.
Can somebody verify each version of MSE 2.0? thanks
XP 32bit - 7,683KB
Vista-7 32bit - ?,???KB
Vista-7 64bit - 9,688KB
XP 32bit - 7,683KB
If it's size of the file then Win7 32 bit is 7,949KB.
I run 64 bit but I d/l the 32 bit just for you to see the size of the file :).
Trying this for myself, anyone else have any positive/negative experiences?
I haven't installed the update from windows update, but MSE is already on version 2.0 since I updated the definitions a day ago.
Maybe they are just doubling up? It doesn't look or act obviously different than the 1.0 version... But then again it doesn't have to deal with anything other than the occasional 8TB scan.
