moving from AGP to PCI-E
M3at
Ok, so I'm moving from AGP to PCI-E and I haven't kept up on the latest and greatest.
My current AGP card is a BFG 6800 GT OC. I'm thinking of getting either another 6800 or something a little better.
I was thinking I might try ATI flavor again, but I'm lost on what cards of ATI's compare to my 6800GT.
I probably wont spend more than what I get for my AGP card so that gives me about 200$ to play with.
Any suggestions are appreciated.
If you are thinking of ATI there are a couple of X850XT cards here:
http://www.newegg.com/Product/Produ...05520549+1069609641&Submit=ENE&Subcategory=48
The X800GTO2's aren't bad but the X850XT is going to give you the most bang for the buck.
nVidea options can be found here:
http://www.newegg.com/Product/Produ...05520548+1069609641&Submit=ENE&Subcategory=48
There seems to be a better selection among the nVidia offerings at your price point, particularly among the 6800 and 7600 series cards.
As for picking up performance going from an AGP 6800 to a PCI-e 6800 I think you won't see a difference. I have 2 X800Pro's - 1 AGP and 1 PCI-e and they run dead even. The benefit of PCI-e is that with cards of the same type such as your 6800's, the PCI-e will be less expensive than the AGP model. The real benefit of PCI-e is in the performance of the newer video cards (7800/7900 nVidia and X1800/X1900 ATI). This is where PCI-e really shines.
If you're going to spend $200, I'd just wait another generation of cards until this current gen becomes next gens midrange (as far as performance goes), this has been the cycle. I don't think you'd see much of a huge performance increase otherwise.
The 6600 GT was a bit more poweful than the 9800 pro. the 7600 GT is a bit more powerful than the 6800 Ultra. So whatever comes out as the next midrage card will most likely be a little more or just as powerful as a 7900/x1900 etc.
so you think the 7600 would be an upgrade from the 6800 GT?
is the ATI x800 comparable to a 6800GT? I ask because someone at my work is selling theirs for 70$.
That COMPLETELY depends on which model. Even then, the card will only be comparable, maybe a bit slower. It also lacks sm 3.0.
As for the 7600GT being a good upgrade option, I'd say that at it's price point (~170 at newegg) it'll be tough to beat, but after having looked at what benchmarks I can find, it's very similar to the 6800GS.
In my opinion your best bet would be to buy a used 7800GT (I don't know if used is a problem). They're selling for $200-$240, and would be a serious upgrade.
Nope, used isn't a problem, not for a 7800GT. hehe.
Awesome! Thanks for the info. I was also considering an ATI x1600 or x1800.
http://www.newegg.com/Product/Product.asp?Item=N82E16814127197
or
http://www.newegg.com/Product/Product.asp?Item=N82E16814102013
There are just too many damn choices!
The x1600 is significantly slower than the 7600GT, and the x1800GTO is about the same speed, as they trade wins on the benchmarks.
In my opinion, if you're able to go used, the BEST bang for the buck is the 7800GT. In fact, that x1800GTO goes for about the same price new as the 7800GT goes for used, and more importantly the 7800GT DESTROYS it.
Yeah - as much as I like ATI cards the X1600 is a huge disappointment. The X1800 cards are ok as long as they are the upper models like the XT but the newer 7600/7800 nVivias are also excellent from what I have seen. It all depends on budget. Anything less than these cards is going to seriously hamper your ability to play the newest games.
turns out one of my co-workers has a 7800 GT BFG that he's going to sell to me for 175$. I think that's probably a pretty good improvement from the 6800 GT. ;)
certainly will be!
strap a vf700 on it and overclock like mad!
initially I was just going to sell my system, and move over to an XPS Laptop from Dell. However, someone I know bought a new SLI board but didn't want to get a pci-e card, so we traded boards.
I think with the 7800GT I'll stick with my desk top for a bit longer. Who knows, maybe I can do enough side work so that I can afford to keep the desktop and buy a decent laptop.
Definitely...and keep an eye out on slickdeals.net for some good deals on laptops..
there was a core duo laptop with all the trimmings for ~650 recently. damn good deal!
