Mouse issue in vSphere client
Discussion in 'Virtualized Computing' started by DeaconFrost, Apr 27, 2017.
  1. DeaconFrost
    DeaconFrost [H]ardForum Junkie
    10,851
    Sep 6, 2007
    We're using the vSphere 6.0 installed "fat client" to connect to two vBlocks and some standalone hosts. Whenever we open the console of a VM, as long as it has a GUI, the mouse usage is very erratic. If you click somewhere, the cursor jumps. It's next-to-impossible to use the mouse.
    We don't have the same issue when using the web console, so it has to be related and confined to the vSphere desktop application.
    Hoping this is a common issue, so has anyone come across this, and more importantly, found a fix?
    Thanks!
  2. lopoetve
    lopoetve Imhotep
    29,106
    Oct 11, 2001
    You have VMware tools installed on the guests? What's the guest OS? This is normally an issue with Linux and not having tools; X.org is funky.
  3. DeaconFrost
    10,851
    Sep 6, 2007
    Yes, VMWare Tools installed on all guests, and updated. The issue is mostly with Windows guests, anything from a few Windows 7 systems up to Server 2016. It happens basically with all guests, except those without a GUI.
  4. lopoetve
    lopoetve Imhotep
    29,106
    Oct 11, 2001
    They're supposed to be using the same set of software between the two.
    Does the mouse exit the screen normally like you'd expect, or does it get captured in the console?
  5. DeaconFrost
    10,851
    Sep 6, 2007
    It exits the window as I would expect. No need to hit CTRL+ALT to get out.
  6. lopoetve
    lopoetve Imhotep
    29,106
    Oct 11, 2001
    What driver is windows showing for the VGA driver?
  7. lopoetve
    lopoetve Imhotep
    29,106
    Oct 11, 2001
    edit: and mouse.
  8. Netwerkz101
    Netwerkz101 Gawd
    663
    Jul 11, 2010
    stab in the dark, but is there any change in mouse behavior if you disable mouse (pointer) trails, changing scheme to "None", verified proper "Hardware" selected (USB / PS2) ?
  9. DeaconFrost
    10,851
    Sep 6, 2007
    This behavior happens across many VMs and workstations connecting to them. Various versions of Windows Server and Workstation, along with a few various Linux distributions. I doubt it is a driver, but which side were you referring to?
    Guest or client system connecting to it? This behavior happens on far more than one system. We have 185 VMs and 5 people on our team connecting via 5 laptops. The problem exists in just about all of them.
  10. lopoetve
    lopoetve Imhotep
    29,106
    Oct 11, 2001
    I'd say call VMware and open a big against that version of the VMRC, but it's EOL so that won't really do any good.
    I've only seen this with bad drivers in the guests; but if it's happening across windows and Linux guests, then you probably have a different issue. The x.org and windows drivers are substantively different, but the VMRC code should be close, so... I'm going with something on your client systems. Could bring in a non domain box to try and access them, see if it's a weird GPO or driver again, but I'd say just stick to the web client.
  11. Netwerkz101
    Netwerkz101 Gawd
    663
    Jul 11, 2010
    I was thinking VM guest but since it happens across Win/Linux .. probably not it.
    Issue only seen when connecting via laptops??
    Are your laptops running the same image .. ie same image = same issue across all of them?
    I've only ever seen similar issues in Windows VMs using funky themes / mouse seetings.
  12. REDYOUCH
    REDYOUCH [H]ardness Supreme
    4,530
    Mar 17, 2001
    Go into the mouse options in Control Panel, go to the Pointer Options tab, and de-select "Enhance pointer precision".
  13. DeaconFrost
    10,851
    Sep 6, 2007
    I had high hopes for that setting, but it didn't change anything for us.
  14. Buster67
    Buster67 n00bie
    1
    May 18, 2017
    I have experienced this same issue when accessing Windows VMs using the 5.5 fat client from a laptop with a QHD display. Never was able to find a solution.
  15. muz_j
    muz_j Limp Gawd
    168
    Jul 13, 2014
    Sounds weird.
    I have 2 random ideas - unsure if they'll get you anywhere, but they're both easy to test out.
    1) what desktop OS is being used on the laptops?
    - would it be appropriate to test using a Basic / high contrast Windows theme....as per this suggestion (I appreciate it's in relation to VMware workstation too):
    https://communities.vmware.com/thread/241944
    2) check your display scaling settings - as per this thread:
    https://communities.vmware.com/thread/520863
    3) is the behavior the same with the vm's display set to both full screen and windowed on the client laptop ?
  16. DeaconFrost
    10,851
    Sep 6, 2007
    None of those worked, unfortunately. We use mostly Windows 10, of various levels, but we have an 8.1 system doing the very same thing. The issue is there on any type of screen, either high-res or a low native res of one of the laptops. The behavior doesn't seem to car about full screen or windowed.
