Mouse cant be detected.
feng2088
I recently put together a new pc for my mom . P4 3G, Asus mobo and 1G ram. After i put everything together, i could easily install an OS on it. But the mouse couldnt be detected during the OS installation. After OS was installed, I tried several mouses and they all did not work. For the optical mouse, the light was up but i couldnt move the arrow and sh!t . I tried all the USB ports and still did not work. Something wrong with the Plug & Play thing? Can someone help me out of it? i am a noob.
kirbyrj said:
Did you try a different mouse?
Way to go advertising those reading skills...
What if you leave one mouse plugged in, turn off the computer, then turn the computer back on after a couple of seconds?
Do all your usb ports go in the back? Tried any other USB items yet?
haha...I was thinking PS2, but didn't write it down.
What drivers did you use? The ones included on the motherboard CD? Are all the chipset components installed correctly?
if the thing has any front mounted USB ports or a additional rear slot bracket with USB ports and they required you to plug in wires to the motherboard, unplug all of them so only only the onboard manuf installed USB ports are available.
Want OS did you install ? What version and what service packs? older versions of windows requires service packs to get the USB working.
Go in device manager and look under "USB devices" or "System Devices" for your USB root hub entires etc. they should appear one place or the other and not have any warnings (yellow or red marks).
Does your bios have the "USB legacy support" or "USB devices controlled by OS " "USB devices controlled by Bios" ? If so change those setting from what they are set at now. I dont have time to look up how they should be set. I leave that to you.
did you install the motherboard drivers supplied by asus after you installed the OS ?
sounds to me you have not installed you motherboard drivers
