Mounting a Wireless AP to Ceiling
Discussion in 'Networking & Security' started by Cod, Jun 7, 2018.
  1. Cod
    Cod Gawd
    640
    Mar 21, 2003
    I just moved into a house with a structured wiring panel and its pre-wired for two wireless access points (1x upstairs, 1x downstairs). The termination points are the panel and square in-wall electrical box in the ceiling (like this: https://www.homedepot.com/p/Carlon-...d-Outlet-Box-Blue-Case-of-100-B118A/100404124). My question is, do I have to buy an AP with a square mounting bracket? if not, how I can mount it with a circle bracket?
    I'm not a handy guy, so any help is appreciated. Thanks.
    Cmustang87 likes this.
  2. BlueLineSwinger
    BlueLineSwinger Gawd
    614
    Dec 1, 2011
    I doubt you'll find any AP that uses the standard dimensions of an electrical box. Most come with their own mounting solution (and possibly the needed screws and drywall anchors) that should be used.
    Cod likes this.
  3. Cmustang87
    Cmustang87 [H]ardness Supreme
    4,372
    Oct 4, 2007
    No problem - what you are loking for is an "in wall" AP. These are very common in hotels and such. Some of them even have a 4 port switch on them with PoE Passthrough. A simple, and cost effective one woudl be from Ubiquiti: https://inwall.ubnt.com
    Meraki makes one as well, but this is a bit cost prohibitive for home users: https://meraki.cisco.com/products/wireless/mr30h
    wra18th and Cod like this.
  4. ChRoNo16
    ChRoNo16 [H]ard|Gawd
    1,393
    Feb 3, 2011
    The AP will come with the needed mounting plate. the box is merely in place so that you can run power at the unit if you with. it has nothing to do with mounting the AP.
    Most people would run the network cable to that box and mount the AP (Using the included wall/ceiling mounts) over where that box is. the box just makes it so u can plug in the cable without it sticking out from the AP
    drklu and Cod like this.
  5. Cod
    Cod Gawd
    640
    Mar 21, 2003
    The Ubiquiti solution may be best since I already have a USG. Would one of these in-wall APs work if mounted on the ceiling? Seems like I'd be limited by the by the beamwidth when its pointing straight to the floor.
    Thanks for all the inputs y'all. From the sound of it, any AP I purchase will work, I may just have to drill an extra few holes for the specific mounting hardware.
  6. antok86
    antok86 [H]ardness Supreme
    8,032
    Feb 26, 2006
    so this was installed on the ceiling. ubiquiti ap comes with a mounting bracket. you mount the bracket so that it covers the “hole” this was on a new home and initially the wires were pulled then the hole was capped with a blank cover. i dont have pics of the bracket only on the ceiling hope that kinda helps
    Cmustang87 and Cod like this.
  7. Cmustang87
    4,372
    Oct 4, 2007
    If it already has the box in the ceiling, you shouldn't have to drill anything. The mounting plate should fit all the standard screw holes in the gang outlet and then the AP hangs to the bracket. Most commercial APs are hung on the ceiling because of RF and how it covers, but this is also for being discrete and preventing any interference.
    Here's the RF patterns of the Unifi Inwall Non-PRO and PRO:
    Cod likes this.
  8. Cod
    Cod Gawd
    640
    Mar 21, 2003
    That does help. That's the exact way my ceiling looks (w/ a blank faceplate) currently. How many extra screws / drywall anchors did the Ubiquiti bracket require?
  9. Cod
    Cod Gawd
    640
    Mar 21, 2003
    From the looks of the chart, an in-wall solution may be best since it won't be required to power anything "behind" it (or in my case, above it) since there will be one on each floor. Thanks for all the info y'all! I really appreciate it.
  10. Cmustang87
    4,372
    Oct 4, 2007
    Here's my Meraki MR30H as a reference. This is installed where Cat5e is run. I just removed the faceplate and connected a 6" Cat5e cable and mount the MR30H to the wall:
    Cod and antok86 like this.
  11. Cmustang87
    4,372
    Oct 4, 2007
    I kept the keystone, just removed the faceplate. The AP sits flush with the wall and mounts to the plate which mounts to the box.
    Cod likes this.
  12. BlueLineSwinger
    614
    Dec 1, 2011
    Hmm, yeah, forgot about those. I was thinking more of standard APs. AFAIK, those in-wall units aren't meant to cover an entire structure/floor, just a more localized area such as a room or two.
    Cod likes this.
  13. S-F
    S-F Gawd
    651
    Aug 5, 2010
    Just screw any AP to the ceiling over the box? These things weigh next to nothing. I'm sure two drywall screws would hold them up just fine.
    Cod likes this.
  14. Cmustang87
    4,372
    Oct 4, 2007
    Typically yea, but it shouldn't be much of an issue in more modern homes that have open floor plans. I get good coverage downstairs with mine and I have another MR33 upstairs.
    Cod likes this.
  15. goodcooper
    goodcooper [H]ardForum Junkie
    9,771
    Nov 4, 2005
    yea, i would simply mount the AP over the hole, i wouldn't mess with the in wall one... those are for hotels and classrooms, not what youw ant in your ceiling...
    really didn't need a box there at all, but it was certainly on someone's drawings somewhere so they felt like they had to add it, plus they needed to terminate and put it ina keystone so they could put a jack on it....
    i think i'd just take the plate off just like you've already described and fill in any holes in the back of the boxes with some expanding foam... be carefull with that stuff, a little goes a long way, lol
  16. S-F
    S-F Gawd
    651
    Aug 5, 2010
    In new construction an inspector would probably demand a box or ring or something. The electrical codes are so bewildering and contradictory that even the code enforcement officials often don't know what to tell people.
  17. goodcooper
    9,771
    Nov 4, 2005
    That's when you ask to see the violation in the code book :p won't see one there for data cable
  18. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,655
    Dec 23, 2001
    I use 2 in wall ac unifi aps and they completely cover my 2500 sqft house. One on each floor and on opposite sides of the house .Even covers my backyard and garage
  19. pendragon1
    pendragon1 [H]ardForum Junkie
    11,991
    Oct 7, 2000
  20. S-F
    S-F Gawd
    651
    Aug 5, 2010
    Low voltage is absolutely under the jurisdiction of electrical code enforcement. In most cases nobody cares. Look at the crazy shit cable guys get away with. Running coax up the outside of a house screwed into the siding. In new construction no electrician could get away with that.
    antok86 likes this.
  21. goodcooper
    9,771
    Nov 4, 2005
    Oh, there are certainly things that can count as a violation with data cable, but having it come out of a hole in some gypsum without a box is not one of them
  22. DangerousMan
    DangerousMan Limp Gawd
    251
    Jan 16, 2006
    The ubiquiti access points come with 2 brackets (one plastic and one metal) and 8 screws; 4 short with anchors for wood/drywall and 4 long with nuts for ceiling pannels. You could easily line up one screw with the outlet box and maybe a 2nd, or make a small hole in the plastic bracket for the 2nd hole.
    If you really want a hassle free option, ubiquiti also sells a universal bracket with all the holes that lineup with any (most) outlet boxes, $8.50 direct from ubiquiti.
