Motherboards you recommend?
CDdude55
Please recommend any motherboard that is good for non overclocking. I don't care it it is SLI just along as it is a good stable motherboard.
Evga nf6 series are good :), check other threads tons of good boards, intel or nvidia based.
Personally, I'd get something like the P5B Deluxe. Great features and good stability. Either that or an Intel branded 965 board.
I was thinking about getting the Asus P5N32-E SLI Plus but i am too scared to get it because of memory problems.
Is there any POST codes like a speaker of a led on the P5B Deluxe?
I think it does the speaker beep. It is very similar to the P5W DH and that doesn't have any LED. I never had any problems with posting, so I never really looked into it.
From the reviews I've read that compare performance across a wide range of current mobos, the P5N32-E SLI Plus was the best performing board with the MSI P6N SLI Platinum coming 2nd, especially, as you say, stock and stable. Most all of the reviews credit the MSI board as the fastest stock board available and only discount it due to not being able to match the OCs of the P5N32-E SLI Plus, the eVGA 680i SLI, and the ASUS P5B-X series of boards. They also credit it as one of the best 'right-out-of-the-box' for stability and speed. It doesn't seem as picky about memory as some of the other nVidia based boards, though with proper planning and initital setup all of the NVIDIA boards will boot properly into BIOS so as to adjust settings as required for your individual components.
Am I biased? Maybe.
I need to adjust my sig; I've been running my E6400@3000.0MHz (375.0x8) 1:1, day in and day out now for a week. :D
The P5N32-E SLI Plus is a x16/x16 SLI solution while the P6N SLI Plat is only x8/x8 IIRC. Both use the 650i, but the Asus uses the 570 chipset also to add the extra x16 for SLI.
I'de recommend saving a bit more cash.. a motherboard is something I wouldn't go cheap on... Unless you don't plan on overclocking.
But I'de recommend Asus P5K series. Mostly because it is a great motherboard.
And futureproof. Will support later cpu's down the road .
Not for overclocking? Intel or Foxxconn. Or maybe ABA.
AM2 is ok. I've built several budget computers based on the X2 3600+ with two different biostar boards. They both work great. Intel seems to have better stock performance though. The E4300 for $115 or so is tough to beat in the price/performance category.
thers so many options yopu can gow ith these days. Good budget builds are very easy to put together. You can techincally make a good pc <$500.. sickening how techology advances so quickly. :D and i love it.
