Motherboard VTT option?
Xenozx
OK, just a quick question if I may.
the DFI X58 motherboard has a set of jumpers for
CPU_VTT voltage
options
1.2v
1.4v
1.6v
Isnt this a setting in the bios? Why is there a jumper for it, and is the default of 1.2v fine for 4.0ghz, or is this changable in both the bios and via jumper?
Is it an overload jumper like on some Asus boards? Although 1.2 and 1.4 seem low to be overload jumpers. That is odd.
I don't think the board will let you go over that value in bios without first moving the jumper. It's kind of like a "just so you're sure you know what you're doing" type of thing. They've done it before with memory voltage. Anything over 2.1V needed to first move a jumper.
