Motherboard setup
i have decided to buy a new system and i have choosed intel D865GVHZ motherboard and because it will be my first self-build pc i am somehow has some fears especially motherboard setup so can anybody help me. :confused:
http://www.pcstats.com/articleview.cfm?articleID=1444
The link above is a basic guide to building a PC. For the most part, it is idiot proof. If something doesn't fit without force then it probably wasn't meant to fit, etc. But that being said, there are some things that can trip you up. My advice would be to learn everything you can about the motherboard you'll be getting, as some of them have some weird nances that need to be known when setting them up. Also, if something doesn't seem to be going right, don't just continue on, defer to a higher knowledge.
