Motherboard Reviews
ddeen
Does it really matter that this motherboard beats that motherboard by a few percentage points? Who cares? You can't tell when your using it. Most good motherboards with the same freakin chipset are going to be within a few percentage points, even ones with different chipsets are going to be within a few percentage points.
Am I the only frigg'n person that wants more out these stupid motherboard reviews than a few benchmarks and pictures? And if I hear one more time that a motherboard must be crappy because it has electrolytic capacitors I am going to SCREAM!! I am right now running an EPOX motherboard with those horrible, sorry, no good for nothing electrolytics and guess what? Its been running the last 6 years without a problem, and its overclocked 40%!!!
Same way with the heatpipes, who cares what is cooling the North Bridge if it's quiet and it works?
How about how the onboard sound worked, or even "gasp" how well the onboard RAID worked, ease of setup, etc.
I know, it take more time and thinking to do something different.
Unless there is a big difference, I don't pay attention to those graphs. The think I usually look at is bios screens to see what kind of options are there. Most of the other stuff should be within a few percentage points across the board, including RAID performance as most of them are using the same chipsets.
The only other thing I like to look at is OC's, just to see what they had their CPU's up to. I the CPU will often have a bigger effect than the motherboard, but always interesting to see. I'll also usually look at the conclusion to see if they overall liked the board or if there was a glaring problem that needs to be addressed in future bioses, etc. Abit boards are often sucky on release bioses, but by the 1.2/1.3 version of them start to round into form.
The benches I do find helpful are those testing the I/O performance of the SATA, IDE,
ethernet, firewire, etc. Not many reviews hit these areas.
