Motherboard Replacement Recommendations?
NeoMatriX724
Hello!
I currently have an Asus P5N32-E SLI motherboard. It has been serving me absolutely terribly so I am looking into a replacement board. The board functions stably for my applications and such...but lock ups occur regularly on gaming etc..Most games don't get past level loading screens etc. I originally thought it was faulty hardware, or crappy drivers, but the more I have looking (and RMA'ING hardware) I have found that it is probably the board.
To give you an idea...
RAM has been RMA'ed 3 Times... Replaced OCZ with Crucial RAM, Crucial went bad and replaced with another set of Crucial.
Video Card -> eVGA 8800GTS RMA'ed twice, first card was legitimately bad, second card appeared to have different issues, but those were related to RAM problems.
2 Harddrives have failed as well. I am beginning to think this board is eating components.
So I'm looking for a replacement. I was looking at the eVGA 680i board as it has had good reviews, however I am hesitant in getting another 680i board. Are there any boards out there with comparable feature sets that have been deemed compatible.
My specs are in my SIG but they have been upgraded to a Q6600 with NO overclock.
I have heard good things about Gigabyte P35 etc.
Any help would be appreciated.
Well what are you looking for in a mobo exactly in terms of features?
My primary reason for buying the 680i board was due to the feature set it provided. I originally felt SLI was a necessary feature for future proofing, but after the fiasco with this board, I feel stability is gonna take more of a precedence.
#1 need is for Quad-Core support, and preferably support for Penryn the future.
#2 need is for RAID. I currently have a 4 drive array running in 0+1, I would like to recreate that on the new board.
#3 DDR2 1066 (1333 support optional) -- I run DDR2 800 right now, would like to have that upgrade avenue open.
#4 At LEAST 1 PCI-e x16 slot
#5 Dual Gigabit would be nice.
#6 Overclockable, Not talking crazy overclocking, but a good amount (as I have a watercooling system standing by for install when I choose a new board)
#7 HD Onboard sound.
I've heard some good things about Gigabyte, ABIT, and Asus (but looking to stay away from Asus due to this board). I can consider a P5K if overwhelming evidence of superiority is provided.
I've been a system builder for a while, but this whole ordeal has shaken my confidence despite it being a combination of poor drivers for 8 series cards, poor chipset design, etc.
I have fallen behind on Intel chipsets because I was an AMD fanboy until the Core 2 architecture came out. We just hit an upgrade cycle at my house...went from 5 nforce2 machines to a variety of nforce 5 and 6 series.
Mostly for future compatibility, for the next few years this will be acting as my primary desktop, and a fileserver on the side.
This also is part of the reason the dual LAN would be ideal. When this machine ceases to be my primary desktop, it will become the backend for our media-network at home. It would act as the file-server and primary recorder while streaming to all the other media centers. (Linux + MythTV is a wondering thing)
Thanks for the suggestion! Have you had any previous experience with Abit?
Experience with Abit customer support? No
Experience with Abit hardware? Yes. Just helped a friend of mine build a new PC with the Abit IP35-E. Worked well and had no problems other than the double boot issue. But I've read that the double boot issue is inherent in the P35 design itself and only happens to a few. It's not a bad thing, just an annoyance at worst.
Also, with Intel Core 2 Duos, it's better to just keep the FSB:RAM ratio at a 1:1 Ratio. Since the new Yorkfield and Wolfdale as well current C2D CPUs only have a FSB of 1333Mhz, all you really need is DDR2 667 RAM for stock settings. But DDR2 800 is usually recommended if you want to do a bit of light overclocking. However if you're trying to get high OCs, it's usually cheaper to get highly overclockable DDR2 800 RAM with Micron D9 ICs then cheap DDR2 1066 RAM.
The Asus P5K-E is another option. Personally, I went for the P35-DS3R and am very happy. I didn't need dual gigabit and didn't want to spend more than $130.
I agree with Danny on the RAM thing. Crucial Ballistix DDR2-800 2GB kit is only $63AR and can reach DDR2-1066 speeds easily. With it, I was able to OC my E6750 to 4Ghz (8x500... unstable; brought it down to 3.8Ghz for stability with 1.55v).
I've been looking back and forth now.....I am torn between wanting SLI capabilities in the future and going with the eVGA 680i A1 board or sticking with more reliable and a P35 from Abit... GAH To think...if we all weren't so computer savvy, we'd be sitting with Dells :D
SLI is only needed for high resolution 3D rendering. So, if you have or plan on getting a 1920x1080 LCD or higher, and want to game on it at native resolution, then keep SLI as an option. Otherwise, theres no need for it, and you won't notice the benefit of running all that pixel processing power. A single GTX is still ok for a 1920x1200 LCD screen, and more cost effective than an 8800GTS SLI setup. SLI as an upgrade path isn't worth it unless, again, a large LCD is in the future plans. There should always be a better single card solution, and you could sell your old card to help offset the cost.
