Motherboard recommendations please
nissanztt90
Looking to build a new PC for my dad. Im not real familiar with the budget/value end of the market here.
What im looking for is an mATX board, dont care if its Intel or AMD. Im going more for value here, so im guessing ill end up going with AMD. I would also like a CPU recommendation as well. OCing isnt out of the question, but very low as far as priorities. If the board can OC, itd really only be a plus, a non OC board isnt really a negative or anything. If anything, id probably just set the FSB and ram to 1:1 and adjust the multiplier accordingly.
This PC will be for my dad, so no gaming, no media stuff really other than maybe the occasional video online, no HTPC type of stuff either. Mainly web browsing, excel, word.
From quick browsing of newegg so far ive come up with...
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131172 paired with an Athlon 64 X2 4800+
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128357 paired with an E5200
My only requirements are an mATX board with onboard video and a dual core processor. I know its somewhat overkill as far as the CPU for what it will be used for, but this PC will likely last him well over 5 years. This will be going in a small case, likely with limited airflow, so the cooler the cpu runs, the better.
Thanks for your advice!
That Gigabyte board is actually a great choice to pair up with an E5200. Since he'll be keeping this machine for a while, I would suggest you go with an E5200 setup, since the additional performance compared to the AMD chip will help extend the system's longevity.
+1 agreed
Thanks guys, i figured the extra 25 bucks or so would be worth it. Keep the opinions coming!
I've used that G31 Gigabyte board before and it was great. It did everything I wanted it to do (except RAID, but that was a little bit of overkill for a $55 board ;) ).
ASRock has a G41 board for maybe $10 more. You might want to look at that also since the graphics are a little better on it compared to the X3100.
Hows the bios on the G31 with OCing options? Is it enough for a mild OC or at least setting ram/fsb speeds?
Memory Dividers
VCore
VDimm
FSB Control
Pretty much the basics.
