robman_rob
- Mar 7, 2006
Hi guys,
I have A8N32 Deluxe SLI motherboard, and I got a few questions to ask.
Question 1:
I have two lan ports, one from Marvell and one from Nvidia. I heard that there are some differences between the two. I heard that Nvidia uses the southbridge while Marvell uses the pci bus. Is there any real differences between using the two?
Q2:
My onboard sound seems to suck, with the volume high, but no actual sound playing, i can heard hissing/crackling and sounds when I am moving my mouse around. Is that normal?
Q3:
I went to buy a X-fi Xtremegamer Fatality Pro sound card but then I read that there are problems with it and nForce4 motherboards (which I happen to have!). Should I return the sound card?
Q4:
I have two slots for PCI Express and only 1 PCI-express video card (7900GT), does it matter which slot I put it in?
Q5:
My motherboard runs around 43C idle and up to like 47C gaming... asus probe alerts me when the motherboard goes over 45 C. My friend said since my motherboard is fanless design then it's designed to run hotter than normal motherboards. Right now CPU is 36C and motherboard is 42C. is that bad?....
ps, how come i can't find the search option anymore?
Question 1:
Q2:
Q3:
Q4:
Q5:
